It is currently May Thu 23, 2013 11:46 am
 Post subject: After sanding
PostPosted: Feb Mon 20, 2012 6:45 pm
I have a very nice cabinet, it's pecan color..I want it darker like walnut or mahogney.
So after the final sanding what is best to wipe off the dust before applying stain?
I used mineral spirets and it left white blotches everywhere.
Thanks, Gary
 Post subject: Re: After sanding
PostPosted: Feb Mon 20, 2012 6:49 pm
Maybe you haven't fully removed the previous top-coating. You ought to try to get down to the bare wood only.
You can try sanding your way down... or try a solution of 50/50 lacquer thinner & acetone.
This will completely remove everything very easily if you wash it on with a steel wool pad flushing the pad in the solution frequently.
PostPosted: Feb Mon 20, 2012 7:52 pm
Hi,
I think Peter has it right, You are leaving the old lacquer finish. Mineral spirits won't dissolve lacquer. Some finishes will soak into the wood and a sanding can't get rid of that. You need a wet wiping to dissolve the stuff.
I usually remove any old finish before sanding or repair is done. I do that because sometimes sanding can embed any wax or silicone that has been used previoulsly. It will grind it into the wood and could lead to trouble later in the process.
Good luck!
Gary Rabbitt
PostPosted: Feb Tue 21, 2012 11:07 pm
Peter, I tried your method. Worked GREAT !!
Thanks, Gary
PostPosted: Feb Wed 22, 2012 1:37 am
Thanks, Gary
You're welcome Gary.
Yep, 50/50 lacquer thinner and acetone.. a perfect solution..( pun intended )..lol
I'll never sand another radio to remove old finish again after having discovered this quick and simple process.
