It is currently May Thu 23, 2013 9:35 am
 Post subject: what tool/method to use
PostPosted: Apr Fri 06, 2012 2:12 am
Okay, have a basket case cabinet that I'm going to try and experiment with veneering. What's the general wisdom on how to handle the decorative cut outs. Sharp knife, sanding block, dremel router or some other piece of equipment? Thanks for any pointers or links
 Post subject: Re: what tool/method to use
PostPosted: Apr Fri 06, 2012 2:16 am
Site Admin
Assuming that the holes are large enough to accommodate it, a Dremel or trim router with a flush cut, bearing guided straight bit provides the neatest, most accurate cut. Otherwise, a very sharp knife such as an exacto knife will work.
The bit (credit to Lee Valley for the image) :
The trim router I used (set up for inlay - not cut-outs) :
The cut-outs using a trim router and flush cut bit as pictured above :
Looking for an old friend - Dan Lafleur, from Carp, Ontario, who attended Earl of March High School.
Post New Topic Post Reply  [ 2 posts ]  Moderator: Peter
