It is currently May Sun 19, 2013 7:19 am
 Post subject: Crinkled finish on Philco 41-280 ...
PostPosted: Apr Mon 09, 2012 1:50 pm
My Philco 41-280 radio has, for a better word, a crinkled finish:
The finish looks dried out.
What do you suggest to improve the appearance?
I've recapped this radio and replaced the Escutcheon, buttons, and knobs - they were melted
as it had been stored in a hot attic by the previous owner.
Most of the rest of the cabinet looks pretty good.
 Post subject: Re: Crinkled finish on Philco 41-280 ...
PostPosted: Apr Tue 10, 2012 1:36 am
I use refinisher with steel wool.
Melts off the laquer, leaves the stain.
Reapply laquer with desired sheen.
This assumes you like the colors/shades and not major wood repairs.
My 2c
Tim
PostPosted: Apr Tue 10, 2012 4:21 am
Looks like you are making good progress.I started on a 285 yesterday. It's pretty bad.....see photo. Where did you get your parts? I can probably repair everything but the dial plate. The escutcheon shrunk and will have to be modified to get it to fit the knobs. Sure would like to find a dial plate, if not more !!
Ed
PostPosted: Apr Tue 10, 2012 1:03 pm
My 2c
Tim
Tim, Howards Refinisher???
PostPosted: Apr Tue 10, 2012 1:09 pm
Those old Philcos don't get much respect, but I find them to be great performers, have a lot of quality, and they look good. My 41-280 is the best AM and SW performer in my collection.
My Escutcheon and pushbuttons looked like your radio - all distorted and melted.
I got my Escutcheon and the pushbuttons at the Radio conference in Charlotte (CC-AWA). I think the vendor was Old Radio Parts -- http://www.OldRadioParts.net
You will have to re-use your brass strip.
For the push buttons, I selected 7 brown ones and a red one - for the ON/OFF function. The Escutcheon and pushbuttons are reproductions that are nicely made.
Replacing the Escutcheon and pushbuttons made a dramatic improvement in looks.
Glass dial plates for these Philcos are available too.
Don't recall where I saw them - anyone else have sources?
Ed
PostPosted: Apr Tue 10, 2012 1:19 pm
I believe your dial glass is sold in reproduction by Radio Daze. Please check the link below:
http://www.radiodaze.com/category/338.aspx
Peter
http://antiqueradioblogger.com/peter
PostPosted: Apr Tue 10, 2012 1:32 pm
My 2c
Tim
No, Formbys makes a "refinisher" that removes old top-coat. There are other brands too. This will leave the stain. You will use a lot of rags but it's effective. http://www.formbys.com/products/refinisher/
Tim
PostPosted: Apr Tue 10, 2012 1:36 pm
Peter
Thank you. Radio Daze has the dial listed. I'll check oldradioparts.org for the escutcheon also. My work is cut out for me !! Ed
PostPosted: May Thu 03, 2012 1:11 pm
Peter
Update
Here is the finished product. Mark O. had everything I needed. Thanks for the information.
Ed
PostPosted: May Thu 03, 2012 3:09 pm
K4YDO wrote:
Peter
Update
Ed
Wow, looks very nice. Did you totally strip and refinish?
PostPosted: May Thu 03, 2012 3:12 pm
What do you suggest to improve the appearance?l
Check out this thread:
viewtopic.php?f=7&t=191049
This technique may work for you.
- Geoff
PostPosted: May Sat 05, 2012 1:35 pm
My 2c
Tim
The wood may not be stained underneath - the color was probably done with toning lacquer which, when removed, would remove the color as well.
PostPosted: May Sat 05, 2012 2:41 pm
If thats the case with the laquer cracking, so would be the stain and it would be time for new.
PostPosted: May Sat 05, 2012 9:07 pm
After a thorough cleaning, spray another coat of lacquer. That will reflow the old layers to a certain extent, then spray with Mohawk Blush Remover/Retarder which will reflow even more. Works great - I've had some lizard-skin finishes that came out almost like new.
PostPosted: Jul Thu 12, 2012 12:14 am
Did you wait until the coat of lacquer fully dried before spraying the blush remover/retarder or while it was still wet?
- Geoff
Post New Topic Post Reply  [ 15 posts ]  Moderator: Peter
