It is currently Jun Tue 18, 2013 11:57 pm
 Post subject: Gluing a plastic radio case
PostPosted: May Sat 05, 2012 5:37 pm
Hello Everyone,
Just wondering, what people use for gluing cracked plastic transistor radio cases?
I glued such plastic before with ABS cement, with super glue, and with "5 minute" epoxy, with various degrees of success.
Which one is preferred, which one is stronger?
Anything else I should consider using or should avoid?
Thanks, Peter
 Post subject: Re: Gluing a plastic radio case
PostPosted: May Wed 09, 2012 1:13 pm
Any comment?
PostPosted: May Thu 10, 2012 1:52 am
I've used "Testors Plastic Cement", it's thinner than water and wicks into the crack and "welds" the plastic together. Cures quickly - not instantly. It says "No. 3502" on the bottle (1 oz). I've had it for years so I don't know if its still available (google it). Contains MEK so it has that wonderful airplane dope aroma.
Vince
PostPosted: May Thu 10, 2012 1:37 pm
Hi Vince,
Thanks for the comment!
I googled that Testors Plastic Cement, it is still available. My main problem with the ABC cement was that it was too thick.
I will try this.
Thanks, Peter
