It is currently May Sat 25, 2013 8:27 pm
 Post subject: RCA BP-10 Case Restoration
PostPosted: Aug Mon 06, 2012 1:39 pm
Hello To All,
I am restoring two RCA BP-10's. I have repaired the electronics on one of them and have moved to the case They both have chipped leather on the case. I have made the existing leather soft again using Scott's Liquid Gold. I am considering using some upholstery leather and recovering the cases. Has anyone ever done this? I am looking for other ideas and suggestions before I commit myself to the first idea.
The other radio has the lid broken away from the hinges. I am still thinking about what to do here. I may make a mold and fabricate a new lid for this one. What have others done?
Ed
 Post subject: Re: RCA BP-10 Case Restoration
PostPosted: Aug Tue 07, 2012 12:28 am
ED:
I've done a couple of them. Doubt the original covering is actually leather, at least on the sets I have. I've used a thin black material, obtained from an auto upolsatrary shop, to recover mine. Came out good.
BOB
PostPosted: Aug Tue 07, 2012 2:21 am
Thank you Bob. That is what I will do. I ordered a yard of vinyl material tonight. I will replace the old covering with it. I appreciate your input.
Ed
PostPosted: Aug Tue 07, 2012 2:30 am
you can also get the leatherette material here for the case.
http://www.micro-tools.com/store/C-568/ ... rette.aspx
PostPosted: Aug Sun 12, 2012 6:21 pm
edcheek wrote:
Hello To All,
Ed
I've recovered BP-10 cases with vinyl material. That's fairly easy. The hard part is BP-10 plastic cover repair. It's apparently a very early type of styrene. I've found that solvent based cement will essentially "weld" the broken pieces. Pressure from a clamp of some sort is usually needed to get the best results. But, the final mended joint is often not as smooth as it could be. Sanding with #400 paper can take care of that. Still the joint doesn't look great, because the cement has discolored the styrene. Spray painting the repaired joint works only if the paint is compatible with the styrene. That usually requires a lot of experimentation. As I said, plastic repair is the hard part. 8)
Post New Topic Post Reply  [ 5 posts ]  Moderator: Peter
Users browsing this forum: RxJoe and 2 guests
