It is currently Apr Wed 25, 2018 1:48 pm
 Post subject: Philco 60 gets a new face!
PostPosted: Dec Thu 29, 2016 3:39 am
Two gouges near the outer face and missing veneer in the speaker area, decided it would look best with a new face. I laid the cabinet on the back side of a sheet of veneer that was enough to cover the all of the front of the cabinet and traced the outside edge of the cabinet onto the veneer. Next I taped a newspaper page to the front of the cabinet and took a crayon and shadowed the scroll on the face, next I taped the piece of newspaper with the shadow to the sheet of veneer and using scissors I cut along the scroll shadow creating the two pieces of veneer I needed to restore the face. I used two coats of Weldwood Gel contact cement to the cabinet and the veneer. Then I placed two pieces of was paper between the veneer and the cabinet, once I was satisfied with the placement I pulled one sheet of the wax paper out and pressed the veneer firmly making good contact. The next step was to remove the next piece of wax paper. I use masking tape to keep the contact cement off the face not getting the veneer. I repeated this process for the second piece of veneer for the middle portion of the front. I use the point of a utility knife (new blade) to trim away the veneer. To fill the grain I use wallboard joint compound. For stain I use Minwax and Behlen Solar Lux.
Larry in NC
 Post subject: Re: Philco 60 gets a new face!
PostPosted: Dec Thu 29, 2016 5:13 pm
So you stuck the new veneer over the old in two pieces each of two sections, an outer and an inner. Hard to follow from the small pics.
Personally, I would have removed the old veneer first, with a wet towel, an iron and a wallpaper scraper. Then, when well dry sanded the ply face smooth and clean. Had one bad episode later with veneer on top of the old so wouldnt go there again.
Gary
PostPosted: Dec Fri 30, 2016 12:10 am
The veneer was tight so I decided to leave it in place, the face had some bad gouges, which was my reason for a new face. Most of the time I do remove the old veneer when restoring.
Larry in NC
PostPosted: Jan Wed 04, 2017 11:43 pm
Here is the cabinet finished.
Larry in NC
PostPosted: Jan Thu 05, 2017 10:25 am
Hard to tell what it looks like from the small, dark image Larry but I hope you are pleased with it.
Gary
PostPosted: Jan Thu 05, 2017 4:08 pm
Wow,
Noce job on that.. Cutting that veneer must have been trying..
What did you use to cut it?
No, I am not old.
I restore old things.
PostPosted: Jan Fri 06, 2017 1:28 pm
Scissors for the rough cut then after gluing the tip of a utility knife.
Larry in NC
PostPosted: Jan Sat 14, 2017 12:27 am
Grill cloth and bezel installed.
Larry in NC
PostPosted: Jan Sat 14, 2017 11:41 am
Better picture Larry. I can see it turned out excellently from where you began. I might have used a slightly lighter grill cloth though just to lift it.
Here's mine, by coincidence the grill cloth is about the same shade as yours but the cabinet is a little brighter and contrasting.
Gary
Post New Topic Post Reply  [ 9 posts ]  Moderator: Peter
cron
