It is currently Oct Sat 20, 2018 5:02 am
 Post subject: Majestic Ritz 666 restoration started
PostPosted: Nov Wed 01, 2017 12:26 am
Rummaging through some boxes acquired from closed radio and tv shops I came across a 460 chassis, speaker, escutcheons and knobs. The chassis seemed familiar so I looked through my files and found where I had restored a Rivera 966 for a customer a few years ago. The parts where in great shape so I decided to build a cabinet. Once I get the cut outs true I will add the piece of walnut veneer to the front and then attach the pilasters.
Larry in NC
 Post subject: Re: Majestic Ritz 666 restoration started
PostPosted: Nov Wed 01, 2017 12:00 pm
Looks like you are a determined man, building your own radio cabinet, why not if you have the skills and time, go for it. . Any blue prints ? where are you getting your measurement's?
PostPosted: Nov Wed 01, 2017 12:35 pm
Fred, I'm retired now and have the time. I found an advertisement with the height depth and width and used those measurement as a starting point. The rest of the dimensions were gathered from those. My last name is dowell so wood working is in the blood(lol).
Larry in NC
 Post subject: Re: Majestic Ritz 666 restoration, first order a cabinet bui
PostPosted: Nov Fri 03, 2017 1:23 am
Had a little shop time yesterday and today to work on the cabinet build for a Majestic Ritz. I laid out and cut the speaker grill area yesterday along with adding the top and the walnut veneer on the front. I used a scroll and a jig saw for the cut outs before added the walnut, I used a utility knife for the veneer. I found a six inch wide fluted door casing at Lowe's that I was able cut down and use for the molding. I made some 60 grit sand paper rasps with number 77 glue and with pads from my orbital sander. the wide flat surface of the rasps enabled me to get the cutouts straight. used finger nail polish on the ends of the front knobs shafts to get placement of their openings. I slid the chassis until the shafts with wet polish made contact with the front of the cabinet. I measured from the bottom edge of chassis to get escutcheon placements.
Larry in NC
PostPosted: Nov Fri 03, 2017 1:28 am
Wow! That is awesome! I'm planning on making a few consoles myself, so am following closely and can't wait to see how this turns out. :D
PostPosted: Nov Sat 04, 2017 1:15 am
Last piece of molding and grain filler applied to the walnut. Maybe I'll get a chance to sand the filler and stain tomorrow.
Larry in NC
PostPosted: Nov Sat 04, 2017 2:21 am
"INCREDIWELL"!!! Going to be a beauty, for sure. Now if I can only find that Factory Advertisement for the 1935-1936 Canadian DeForest Crosley 'Oxford' model Table Radio ~ I'll be in business!!! HA.
Want DeForest Crosley Advertising ~ 1935!
Marconi; Stromberg Carlson
CKTA 1570 AM "Drive"
PostPosted: Nov Sat 04, 2017 5:49 am
WOW LARRY, looks great.
If you get a chance I'd like to talk to you sometime.
cheers
73, Ron w4ron
PostPosted: Nov Sat 04, 2017 1:44 pm
Ron email me at larrydotdowell47atgmaildotcom and I will pass along my phone contact.
Larry in NC
PostPosted: Nov Sun 05, 2017 6:00 pm
Cabinet gets first coat of stain, black and dark walnut, with the pilasters getting Van Dye Brown aniline dye.
Larry in NC
PostPosted: Nov Mon 06, 2017 6:27 pm
Must be very satisfying doing that and its looking good. And so close to the image on RM.org. Really excellent work.
Gary
 Post subject: Re: Majestic Ritz 666 restoration started (cabinet finished)
PostPosted: Nov Thu 23, 2017 3:13 pm
Here are a couple of pictures of the Ritz cabinet. The grill cloth is from Richmond Design small herringbone reversed. Once I finish restoring the chassis I'll post one more set of photos.
Larry in NC
PostPosted: Nov Sun 26, 2017 12:03 am
I noticed I didn't have the escutcheons at the same location from the top of the cabinet, I raised the one on the left and lower the one on the right to get them equal distance from the top of the cabinet. There was a tag on the chassis that stated it worked but only two of the capacitors had been replaced and the speaker cone had a couple of cracks. I repaired the speaker using GE silicon and replaced all of the paper and electrolytics. I will fire it up next trip out to the shop!
Larry in NC
 Post subject: Re: Majestic Ritz 666 restoration started (finished)
PostPosted: Dec Sat 09, 2017 12:30 am
Here are the final pictures of the restoration of a Majestic Ritz model 666! Reasonably pleased with how it turned out. Pretty good sound also. In the Raleigh Durham area of North Carolina Curtis Media Group has a number of AM stations one of them is AM 850 "Just Right Music" a station I grew up with in the sixties and now I'm reliving some of the music I grew up with on the radios I restore!
Larry in NC
PostPosted: Dec Sat 09, 2017 1:33 am
Larry:
Great job!
BR,
Terry
PostPosted: Dec Sun 24, 2017 4:16 pm
Thanks Terry it was a fun project, please with how it turned out. The radio has a nice sound.
All the best and Merry Christmas and Happy New Year, Larry
Larry in NC
Post New Topic Post Reply  [ 16 posts ]  Moderator: Peter
Users browsing this forum: RQuam and 3 guests
