It is currently Jul Tue 17, 2018 6:48 am
 Post subject: Wood cabinet...lacquer?
PostPosted: Nov Sun 19, 2017 9:50 pm
Hi all.
I'm in the process of applying lacquer to finish a cabinet restoration and I keep getting the "a bad orange peel effect".
I used pre-stain, minn wax stain and let it dry for 5 days and lacquer spray gets the orange peel effect.
Bought a new can of Rustoleum high luster lacquer and still does it.
The weather here is 76 degrees and 41% humidity.
Also applied a coat of equal parts denatured alcohol, lacquer thinner and shellac and still get the orange peel with the lacquer.
Any help is appreciated.
Carlos
 Post subject: Re: Wood cabinet...lacquer?
PostPosted: Nov Mon 20, 2017 9:59 am
Temp and humidity sound fine; wonderful as we shiver here :)
Usually its down to the spray can nozzle. The best cans for me are Mohawk with the large thumb sized button and nozzle.
I spray with each surface horizontal by hanging the cabinet off of battens clamped to a bench. Front is done on a low table. Reckon to wet out slightly but not go too far: experience again.
Rarely see orange peel and usually easy to rub out what little is there.
You can check that there is no problem with the surface by spraying a piece of smooth, clean (wipe over with IPA or thinners first) melamine faced panel and see how that comes out. Can compare lacquers that way as well.
Gary
PostPosted: Nov Mon 20, 2017 3:43 pm
Thanks, Garry.
I appreciate your reply.
Carlos
Post New Topic Post Reply  [ 3 posts ]  Moderator: Peter
