It is currently Nov Sat 17, 2018 5:39 am
 Post subject: late 1920's grill cloth pattern?
PostPosted: Nov Mon 27, 2017 2:20 am
Now that the electronics are working properly in my Atwater Kent Model 55 console, I can focus on making a new speaker mounting board (the original is missing).
The board itself should be easy enough: just a piece of 5/8" plywood cut to size, drilled for screws, and with the F-4 speaker's mounting hardware attached. However, since the speaker mounting board is missing...so is any and all trace of the original grille cloth.
The cabinet itself isn't marked as to who made it. What I want to find, is some new-made grille cloth that would be appropriate for a late 1920's console. One that isn't indicative of any particular brand (unless it's specifically Atwater Kent! :D ), but that doesn't scream "1930's!".
Can someone point me to some appropriate patterns? I don't know enough about antique radios to be able to tell a 1920's appropriate pattern from a 1930's one, and I want to do this right and have it look good, and look CORRECT.
 Post subject: Re: late 1920's grill cloth pattern?
PostPosted: Dec Sat 23, 2017 12:52 pm
http://www.radiodaze.com/grille-cloth/
Some of the patterns here are typical of late 20's radios. Usually more subdued patterns. You did not see the loud patterns too much till the late thirty's. Patterns, #2, 5, 14, 44 come to mind. Just my opinion.
Paul
...... how hard can it be?
PostPosted: Dec Sat 23, 2017 1:38 pm
This is what I ended up using. Got it from Bret's Old Radios on EBay (he recommended it):
ImageAtwater Kent Model 55C
ImageAtwater Kent 55C
PostPosted: Dec Sat 23, 2017 1:54 pm
It looks like a good selection to me.
Paul
PostPosted: Dec Sat 23, 2017 6:55 pm
And to me with nice straight lines as well.
Gary
PostPosted: Dec Sat 23, 2017 8:42 pm
Thanks! I'm happy with how it turned out. It's Bret's pattern #20. He even asked if he could use my photo in his listing!
