It is currently May Fri 24, 2013 3:03 pm
 Post subject: Silvertone 4781 Bezel ... pics???
PostPosted: Jan Wed 18, 2012 6:23 pm
I just received a Silvertone 4781 (1938) - someone had already started to strip the cabinet, but did not completely strip it. My only problem with restoring this unit is the plastic dial bezel trim for the cabinet is missing.
I found a older post from last year from another person on this forum looking for the same part with no responses. He mentioned model 4666 and 4681 have the same bezel.
Knowing I most likely will not be able to locate a replacement bezel, I'm looking for some close-up detailed pictures of this bezel so I can attempt to fabricate one from a chunk of hardwood or the like. I can't find any good pictures on Google image search either that shows the bezel in detail.
Do any of you have any of these three models? If you do, can you snap some good detailed pictures of this bezel so I can model a new one after the pictures? From the low-res Google pics I did find, it looks to be a curved plastic bezel to fit the hip on the top of the cabinet and has a clear opening for sighting the dial 'drum' and the magic eye.
Thanks!
Joe
 Post subject: Re: Silvertone 4781 Bezel ... pics???
PostPosted: Jan Mon 23, 2012 5:03 am
Pic of 4666 on Radiomuseum. http://www.radiomuseum.org/r/sears_roeb_4666.html
Don't know if this will help.
Bill
PostPosted: Jan Wed 25, 2012 6:30 pm
Thanks Bill - this should be fun to duplicate! It will take some time and lots of carving and sanding and maybe even experimenting with heating and bending a plexiglass inlay, but I'm confident I'll be making one from scratch for my radio.
I'll figure something out and post pics when the bezel is completed...
Joe
PostPosted: May Thu 03, 2012 8:23 pm
Joe
Hey Joe - did you ever get to trying to duplicate this bezel? If so, sure would like to see some pics, if available?
Post New Topic Post Reply  [ 4 posts ]  Moderator: Peter
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 3 guests
