Page 1 of 1
[ 10 posts ] |
| Author |
Frank Giardino
Post subject: ID Volt Meter Posted: May Sun 27, 2012 1:00 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 910 Location: Rome New York USA
| Top |
Dennis H.
Post subject: Re: ID Volt Meter Posted: May Sun 27, 2012 2:18 am |
Joined: Aug Mon 17, 2009 4:11 pm Posts: 1759 Location: DFW Texas
| Top |
stevebyan
Post subject: Re: ID Volt Meter Posted: May Sun 27, 2012 2:22 am |
| Member |
Joined: May Wed 18, 2011 2:40 am Posts: 563 Location: Littleton, MA
| Top |
Frank Giardino
Post subject: Re: ID Volt Meter Posted: May Sun 27, 2012 2:44 am |
Thanks, now for another question, is the senior meter the same as the meter movement on the junior? A forum member is looking for one for a jr, and I have one for the sr. This will be a difficult question.
Thanks, Frank
| Top |
stevebyan
Post subject: Re: ID Volt Meter Posted: May Mon 28, 2012 2:28 pm |
| Member |
A quick check of the WV-77E Junior VoltOhmyst manual at BAMA shows it uses a 400 uA meter, RCA p/n 217925. A check of the WV-97A Senior VoltOhmyst manual from ebaman shows it uses a 200 uA meter, RCA p/n 59523.
_________________ Steve Byan http://www.byan-roper.org/steve/steve-at-play/
| Top |
stevebyan
Post subject: Re: ID Volt Meter Posted: May Mon 28, 2012 2:33 pm |
| Member |
On the other hand, a check of the WV-77C manual at ebaman shows it using a 200 uA meter, RCA p/n 213484. Does your Senior VoltOhmyst meter have any part number or indication of its sensistivity?
| Top |
Lou deGonzague
Post subject: Re: ID Volt Meter Posted: May Mon 28, 2012 7:40 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 7080 Location: Latham NY
There is a piece of tape on it that says 250ua FS.
| Top |
stevebyan
Post subject: Re: ID Volt Meter Posted: May Mon 28, 2012 10:25 pm |
| Member |
So it does! So I guess the question now is which model of WV-97 used a 250 uA meter movement? Just how many models of the WV-97 did RCA make? All I see on the web is WV-97A, but the manual for that says it's a 200 uA meter. Maybe the tape label is wrong?
| Top |
Lou deGonzague
Post subject: Re: ID Volt Meter Posted: May Mon 28, 2012 11:59 pm |
That would be my guess, the person testing may not have had the proper equipment and/or ability to do so.
| Top |
Mikeinkcmo
Post subject: Re: ID Volt Meter Posted: May Tue 29, 2012 2:07 am |
Aside from the FS being different, the wv-77 meter and cabinet are considerably narrower than the later Sr., don't think it'll fit. If you're thinking about just putting the Sr's movement in the Jr's case, That would open up another barrel of snakes.
| Top |
Page 1 of 1
[ 10 posts ] |
