It is currently Jul Fri 21, 2017 3:30 pm
 Post subject: Superior model 82-A tube tester
PostPosted: May Mon 14, 2001 6:00 am
I aquired a superior Instruments Rapid Tube Tester Model 82-A at an auction on the weekend. It has been built into the lid of a homemade wooden tube caddy, which was full of NOS tubes (Why I actually bought it).<BR>There is no power cord or instructions with the tester, I have no idea if it works or not. Does anyone know if this is a halfway decent instrument?<P>A tube tester would be useful to me, at least save me the 1/2 hour drive to AES when I need to check a tube. But I don't want to sink lots of time and effort into trying to get it working if it is crappy either.<P>Any ideas where I could find a copy of the manual with all the tube specs?<P>------------------<BR>-Mike
PostPosted: May Tue 15, 2001 1:18 am
I've never run across an 82-A, but in general, Superior was not among the elite of tube tester makers. It's probably an emission tester at best. Not a lot to go wrong with these things, though. The circuit is apt to be the same as a Heath or low-end Eico 625/628.<P>------------------<BR>
PostPosted: May Tue 15, 2001 6:49 am
I have an 82-A and it is the most basic of tube testers, emission only. There is not much to go wrong with this tester. I aquired a copy of the model 82 tube chart which works on the 82-A. The only difference between the two models I can see is the 82-A has the additional panel installed which has a newvistor, compactron, and 10 pin(I think)sockets.<P>------------------<BR>
PostPosted: May Sun 20, 2001 6:49 pm
Mike,<BR>I have an 82-A and will contact you separately to send copies of the instructions and a tube settings list if you need them. <P>Larry Hausheer<BR>Schenectady, NY<P>------------------<BR>
 Post subject: Re: Superior model 82-A tube tester
PostPosted: May Sun 17, 2015 2:54 am
I also purchased this item and need some instructions on how to use it properly. Anyone have a copy? Thanks!
PostPosted: Jul Mon 17, 2017 5:59 pm
i just was giveen this unit does anyone have the charts for it? mine didnt come with any
PostPosted: Jul Mon 17, 2017 6:11 pm
Send your email address to me in a PM and I can send the 1959 chart in a pdf.
PostPosted: Jul Mon 17, 2017 6:54 pm
pm sent.. thank you very much
PostPosted: Jul Mon 17, 2017 6:56 pm
You can download it at
http://bama.edebris.com/manuals/superior/82adata/
PostPosted: Jul Mon 17, 2017 7:56 pm
thanks guys!
Users browsing this forum: D R FORD, Google Adsense [Bot] and 15 guests
