It is currently May Mon 20, 2013 9:49 pm
 Post subject: Schwarzbeck FSME 1515 EMI Receiver Problems
PostPosted: Mar Sun 11, 2012 5:20 am
I recently aquired a Swarzbeck FSME 1515 EMI receiver and it dead or near dead on some of the bands.
Can anyone help with service information or a schematic?
As usual Thanks in advance.
Knowledge is useless unless you can share it. KA5OBI
 Post subject: Re: Schwarzbeck FSME 1515 EMI Receiver Problems
PostPosted: Mar Mon 12, 2012 5:46 pm
I think I have figured it out. I laid it down under power on it's side to get to another piece of equipment and it started working. There are 2 rf inputs with a switch in between them and I started playing with the switch and I could get a signal some times. I laid the unit face up power off and dripped some contact cleaner into the toggle switch shaft and worked the switch back and forth rapidly. I let the contact cleaner dry for a little while and when I turned the unit back on I was getting signals. Some times it's better to be lucky than good.
Users browsing this forum: Nelson in Winnipeg and 6 guests
