Page 1 of 1
[ 19 posts ] |
| Author |
Tubenut
Post subject: WWVB is playing around until Saturday Posted: Mar Fri 09, 2012 11:29 am |
Joined: Oct Sun 11, 2009 10:06 am Posts: 1441 Location: British Columbia
For those of you that have a Disciplined Oscillator that uses the 60kHz time signal, They have been playing with some new Format. During the test, Station WWVB will be broadcasting amplitude modulation and phase modulation simultaneously. So this equals a nice red FREQ lamp on your 8164, or equivilant Spectracom. So don't go through the hastle of trying to diagnose your equipment, LIKE I DID http://www.nist.gov/pml/div688/grp40/wwvb.cfm
| Top |
Mikeinkcmo
Post subject: Re: WWVB is playing around until Saturday Posted: Mar Fri 09, 2012 3:15 pm |
Hi Paul, Don't know what the problem is with your Spectracom 8164 is, but my HP 117 hasen't been affected in the slightest. Its been off for the last couple months or so, so mebby that's why, but.... Interesting, short announcement and I didn't see any mention of what the ultimate goal might be, any Ideas?
| Top |
Erik K
Post subject: Re: WWVB is playing around until Saturday Posted: Mar Fri 09, 2012 4:24 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1527 Location: St. Paul, Minnesota
There's also been a major solar storm, which the 8164's don't like. Mine's been going off lock in the evening for a couple hours each night since Tuesday.
| Top |
Mike Yancey
Post subject: Re: WWVB is playing around until Saturday Posted: Mar Fri 09, 2012 5:21 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1024 Location: Dallas, Texas USA
Well, that's very interesting. I have a home-brew WWVB clock - it's basically an update to an old SB-630 Station Console. It uses a C-MAX CMMR-6P receiver in it. http://km5z.us/SB-630_console.phpDuring this weeks's Solar 'festival', it's been pegged at full strength / no errors. I think it's been syncing itself every minute. I thought that very odd, since HF was in terrible shape - 80m and 40m were filled with a constant background noise. 40m was much better last night. Mike Y KM5Z
| Top |
mescalero
Post subject: Re: WWVB is playing around until Saturday Posted: Mar Fri 09, 2012 5:37 pm |
Joined: Feb Thu 24, 2011 1:29 am Posts: 2802 Location: Dallas, TX - in the city but with bobcats and coyotes
Off topic: Mike, about fifteen years ago, during solar storm, I picked up TV channel 3, from Wilmington Beach, NC. I was in my house in Carrollton, TX.  The video and audio were full quieting for a little under ten minutes, long enough to catch some programming and a "local" ad or two (I got station ID this way!) and then it was gone. I sent a QSL but heard no reply.  It's a darn shame that they didn't actually employ engineers anymore.. An engineer would have returned the QSL! Six meters can be a lot of fun too during these events.
_________________ In a triode, no one can hear you screen.
| Top |
Erik K
Post subject: Re: WWVB is playing around until Saturday Posted: Mar Fri 09, 2012 7:48 pm |
Clocks only sample WWVB periodically, so they're not likely to be affected (as the WWVB posting points out).
I hope WWVB doesn't make permanent changes that will affect sensitive continuous-monitoring gear like frequency standards, since making and maintaining antennas that can reliably drive those is a tough enough task already.
Frankly, I used to be concerned they're phase out WWVB as newer technologies made it increasingly irrelevant, but then along came cheap, atomic-reference clocks to save that day.
| Top |
Tubenut
Post subject: Re: WWVB is playing around until Saturday Posted: Mar Fri 09, 2012 11:46 pm |
The Spectracom I use will not work with the present system. Today at 10:00AM PST they stoped the experiment for 1 Hour. My Spectracom returned to normal for that hour. There is no way to acheive phase lock when they are broadcasting amplitude modulation and phase modulation simultaneously. Just because the lock light is illuminated on the front of your receiver, doesn't mean it's locked on the timing signal. That simply means that it see's an RF signal at 60kHz. At 60kHz, the solar storm seems to make no difference. The signal is strong into the spectracom front end as seen on a scope. The Solar storm will however affect the GPS receivers, as the storm affects frequencys in the GHz region.
| Top |
Tubenut
Post subject: Re: WWVB is playing around until Saturday Posted: Mar Sat 10, 2012 12:03 am |
| Top |
Tubenut
Post subject: Re: WWVB is playing around until Saturday Posted: Mar Sun 11, 2012 1:05 am |
Thankyou WWVB for returning to your regular format, My Spectracom is also very Thankful.
| Top |
Monarke4
Post subject: Re: WWVB is playing around until Saturday Posted: Jul Tue 10, 2012 5:18 am |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 217 Location: los angeles, california, usa
Tubenut wrote: For those of you that have a Disciplined Oscillator that uses the 60kHz time signal, They have been playing with some new Format. During the test, Station WWVB will be broadcasting amplitude modulation and phase modulation simultaneously. So this equals a nice red FREQ lamp on your 8164, or equivilant Spectracom. So don't go through the hastle of trying to diagnose your equipment, LIKE I DID http://www.nist.gov/pml/div688/grp40/wwvb.cfm Pardon my complete absolute ignorance, but what do you use the Spectracom 8164 for? After looking one up it seems like a very large and expensive to operate desk clock...
_________________ Donald R. Resor
N6KAW
www.hammondorganservice.com
| Top |
Tubenut
Post subject: Re: WWVB is playing around until Saturday Posted: Jul Tue 10, 2012 6:55 am |
Hi Don. It's a little more than a clock . Its an oscillator controlled by the WWVB to keep all my test gear at 10.0000000Mhz
| Top |
Monarke4
Post subject: Re: WWVB is playing around until Saturday Posted: Jul Tue 10, 2012 7:06 am |
| Member |
| Top |
Erik K
Post subject: Re: WWVB is playing around until Saturday Posted: Jul Tue 10, 2012 2:26 pm |
Yes, the chart recorder has either been removed from the one pictured, or it's out of paper. I can't really tell from the pictures, and it's been so long since I changed paper in mine, I can't remember what it looks like in front.
BTW, they're not that large either, smaller than, say, an HP 5335A. They make good napping spots for cats too.
| Top |
stevebyan
Post subject: Re: WWVB is playing around until Saturday Posted: Jul Tue 10, 2012 5:41 pm |
| Member |
Joined: May Wed 18, 2011 2:40 am Posts: 518 Location: Littleton, MA
Mikeinkcmo wrote: Don't know what the problem is with your Spectracom 8164 is, but my HP 117 hasen't been affected in the slightest. Its been off for the last couple months or so, so mebby that's why, but.... Interesting, short announcement and I didn't see any mention of what the ultimate goal might be, any Ideas? There's been a lot of discussion on this on the Time-Nuts mailing list. WWVB is moving to a BPSK modulation format which breaks most phase-comparing receivers. According to John Forster: The HP 117 and Fluke 207 will not work. Many Spectracoms will not work. A few will. See their web site The Stanford 620 will not, I believe. Some models may. The new modulation is compatible with consumer "atomic clock" receivers, but not most of the existing precision phase comparison receivers. The new BPSK scheme is intended to improve the reliability of the WWVB time signal for small consumer "atomic clock" receivers on the east coast of the US. See the paper "New Improved System for WWVB Broadcast", Lowe, J., et al, presented at the 43rd Annual Precise Time and Time Interval Meeting. Apparently not all the details are disclosed in the paper, and there is a private company preparing silicon and patents for receivers based on the new modulation scheme: http://www.xtendwave.com/xtendwave-awar ... ments.htmlhttp://www.xtendwave.com/atomictimekeeping.htmlIt's time to ditch your HP 117 and move on to a GPS-disciplined time reference for your lab.
_________________ Steve Byan http://www.byan-roper.org/steve/steve-at-play/
| Top |
stevebyan
Post subject: Re: WWVB is playing around until Saturday Posted: Jul Tue 10, 2012 5:51 pm |
| Member |
Tubenut wrote: But I hope they don't try to stick with this new format, or our 60kHz standards may need some form of adaptor to make them operate properly. Yep, they are moving to the new format, and your 60 kHz standard is toast without an adapter which may or may not be produced and which may or may not be affordable by hobbyists. It's probably cheaper to pitch your Spectracom and switch to a GPS discplined oscillator for your lab, using a Trimble Thunderbolt from eBay.
| Top |
Tubenut
Post subject: Re: WWVB is playing around until Saturday Posted: Jul Wed 11, 2012 3:35 am |
Hi Steve, yes they are moving to a new format. I receive e-mails from John Lowe at the WWVB quite frequently, letting me know they are playing with their new system. Its nice that he provides times and dates so I know my Spectracom isn't haywire. This last test period they restored normal operation for 1 hour a day, which made my standard happy. I didnt get the tell tale warning lamps. The first time they did the test, my Spectracom looked like a Christmas tree with all the red warning lamps on.
| Top |
MarkPalmer
Post subject: Re: WWVB is playing around until Saturday Posted: Jul Fri 13, 2012 7:26 am |
| Member |
Joined: May Mon 18, 2009 5:55 pm Posts: 2025 Location: Erie, PA
Oh boy. Looks like E-Bay and hamfests will will be flooded with piles of Spectracoms and other WWVB receivers just after the last load of useless LORAN-C timebase receivers that no one could get rid of hit the bottom of the dumpsters. -Mark-
_________________ My Current Projects: http://www.facebook.com/#!/pages/Marks- ... 4487855125
| Top |
Monarke4
Post subject: Re: WWVB is playing around until Saturday Posted: Jul Fri 13, 2012 7:35 am |
| Member |
| Top |
mescalero
Post subject: Re: WWVB is playing around until Saturday Posted: Jul Sun 15, 2012 3:40 pm |
stevebyan wrote: Tubenut wrote: But I hope they don't try to stick with this new format, or our 60kHz standards may need some form of adaptor to make them operate properly. Yep, they are moving to the new format, and your 60 kHz standard is toast without an adapter which may or may not be produced and which may or may not be affordable by hobbyists. It's probably cheaper to pitch your Spectracom and switch to a GPS discplined oscillator for your lab, using a Trimble Thunderbolt from eBay. Quoting John Cleese: "We've already got one and it's very, very nice.!" I just bought one and have it up and running in less than two hours time for under $200.00. The "Lady Heather" software had some screen size issues with one monitor but I am not running it on that PC anyway. The readme file explains starting with various screen sizes, COM port choice, etc... I should be good to go for a few more years. I had to provide an antenna and power supply (+/-12v, +5v). Life is good. 73 de KB5SHC
| Top |
Page 1 of 1
[ 19 posts ] |
Users browsing this forum: gygagnon and 4 guests |
