It is currently May Sun 19, 2013 2:44 pm
 Post subject: got my self a 539c and....
PostPosted: Apr Sat 28, 2012 11:32 pm
Recently I came across an old Hickok 539C from an old gentleman who passed on. I have a few questions about this tester I would like to ask here as I found this board on the internet and it looked like a good place to ask.
I opened the ol' tester today and changed out the 9 pin socket as the old one was worn and I noticed the selection switches were pretty well grooved from much use over the years. Most of the switches feel a little stiff when turning except for the Cathode selector, which is smooth and turns easier then the rest. Maybe it was replaced, I am not sure. It got me to thinking about the other switches that are a little harder to turn. My question is ... Should I lube the switch contacts with some type of lubricant or oil to hold down on the wear of the brass contacts?... or is that a bad ideal.
By the way my name is Blaine... I am kinda new to the ol testing equipment but find it captivating.
Thanks in advance for any help you may give on this thread.
 Post subject: Re: got my self a 539c and....
PostPosted: Apr Sun 29, 2012 12:13 am
Bad idea. These sw are very sensitive to leakage paths that could be crated by oil and dirt mixture, also the phenolic material can swell from the oil. Best to use a non-residue electronic cleaner and just a tiny drop of oil on the bering part of the sw. Usually there is a detent mech in front of each sw that uses a captive ball bering or 2 that could use that drop of oil. Nice find on one of the most desirable testers out there :mrgreen:
PostPosted: Apr Sun 29, 2012 5:30 am
Thanks Lou
it was cool to find the old tester at an estate sale
its an old war horse of a tester.I tested tubes off and on for about 12 Hrs today with it,
I was thinking maybe I should put a fan in the old girl to help cooler it down but I hate the idea of cutting a hole in the side for the fan
do you think a fan would be a good idea for the 539c?
thanks again
PostPosted: Apr Sun 29, 2012 5:53 am
It might be a real disaster introducing dust into all those switch decks . Leave well enough alone in this case .
Mark
PostPosted: Apr Sun 29, 2012 12:44 pm
You probably won't be running it for so long, once you get many of your tubes tested. You could temporarily prop up the panel on thin wooden spacers, to get a little ventilation.
As Lou mentioned, a tiny bit of lubricant on the contact surfaces and the bearing surfaces is all you need. The silver plating will be long gone by now, so it's brass on brass, but regular use will keep them relatively clean. The original grease on the steel parts will have dried out, but if you're lucky, some new oil will soak in and keep the bearings from freezing solid.
PostPosted: Apr Sun 29, 2012 1:55 pm
Whatever you do, DO NOT spray any of the switches with ANYTHING. Doing so will introduce leakage and the tester will never be accurate.
Gene
'The only thing constant is change'.
Member: TCA
PostPosted: Apr Mon 30, 2012 12:21 am
thanks for all the info guys .it is very much appreciated
I ran the old girl for another 10 Hr.s today testing a bushel of 6dj8's
its taking me about 7 to 10 min.'s per tube
I hope the old tester can handle the load.
I came across 15 of the big old Tektronix Type 585A and the like at an auction and man they where full of the old bugle boys
so I ended up with over a 100 6dj8's
all ready I can see my new 9 pen socket I just put in the other day is getting janky
thanks again for the info :roll:
PostPosted: Apr Mon 30, 2012 12:29 am
avatar test
PostPosted: Apr Mon 30, 2012 5:02 am
Careful. Them's fightin' words, pardner. :shock:
Many, if not most, of us on this forum go to truly -great- lengths to restore the fine equipment such as that which you seem to have so callously gutted. Seriously, that's considered by many here to be bad, bad juju.
Of course, it is yours to do with as you see fit. :roll:
BTW: Seeing as how the damage is done, you might could offer up some of the other parts for those of us who are bent upon restoration and homebrew. Just a suggestion.
My opinion? If you want truly great audio, let us teach you how to use the test equipment. If you just want piles of cash, well, to each their own.
PostPosted: Apr Mon 30, 2012 6:12 am
I think I see ebay in someones future.
PostPosted: Apr Mon 30, 2012 12:24 pm
(((((Careful. Them's fightin' words, pardner. :shock:
My opinion? If you want truly great audio, let us teach you how to use the test equipment. If you just want piles of cash, well, to each their own.)))))
LOL.I understand
I started to pull parts of the old TEK's and it made me sick so I stopped.
out of 15 0r so TEKS I only pulled 1 power light other then the tubes .I all so found a bunch of old radios and the like at an estate sale,I am going to put up some pic of the stuff when I figure out how
((((( I think I see ebay in someones future.
Dave)))))
lol.your crystal ball is working Dave as I have been making a living on ebay for 10 years now.it is my soul source of income and it has been a wild ride,I was there in the hay day.ebay has changed a lot sense then
nice to meet you folks and I will keep the bad juju down to a minimum
PostPosted: Apr Mon 30, 2012 12:26 pm
vid test of the old 539c I found
<object width="420" height="315"><param name="movie" value="http://www.youtube.com/v/HXafFv9toxk?version=3&amp;hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/HXafFv9toxk?version=3&amp;hl=en_US" type="application/x-shockwave-flash" width="420" height="315" allowscriptaccess="always" allowfullscreen="true"></embed></object>
PostPosted: Apr Mon 30, 2012 12:28 pm
hmmmmmm no worky for me
http://www.youtube.com/watch?v=HXafFv9t ... ature=plcp
PostPosted: Apr Mon 30, 2012 12:31 pm
PostPosted: Apr Mon 30, 2012 12:33 pm
Hmmmmmmmmm still no worky for me
<iframe width="420" height="315" src="https://www.youtube.com/embed/HXafFv9toxk?rel=0" frameborder="0" allowfullscreen></iframe>
PostPosted: Apr Mon 30, 2012 12:39 pm
maybe I should start with a simple pic,lol
PostPosted: Apr Mon 30, 2012 12:54 pm
looks like I can only do pics,O well,
I am going to put up a few pics of some of the stuff I got at an estate sale a few weeks back.
been trying to figure out what some of this stuff dose.
I was going to sale it all on ebay but it was just a little to cool to let go.
so I built a bench , hooked up the power and now just look at me, I am an old radio guy.lol
I herd you chuckling threw the wires.
here is a device that came with the old guys batch.I never met the man but I could tell he was cool from his house and his things.he was in his upper 80's and could still build every PC in his house,one of which I am typing on and using now .
PostPosted: Apr Mon 30, 2012 1:01 pm
some more things from that same sale
PostPosted: Apr Mon 30, 2012 1:11 pm
and some more stuff I don't know what da hell is but it looks cool enough
PostPosted: Apr Mon 30, 2012 1:25 pm
my new old radio guy room ,
if you didn't know any better you'd think I knew what the hell I was doing
