It is currently Jun Wed 19, 2013 10:44 pm
Post New Topic Post Reply  [ 44 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: What is your preferred ESR meter and why?
PostPosted: May Fri 25, 2012 10:56 pm
Concerning vintage electronics from the 20s to the 50s it is a waste of time to test the old paper and electrolytic caps, but there is one application for an ESR meter: testing the NEW parts that are about to be installed. Considering where they are made today, I think it is essential to at least do a spot check of components when they are received from a vendor. Of course, caps below .47 will not read, so a power supply and micro-ammeter are needed to test those.
PostPosted: May Sat 26, 2012 12:20 am
Hello Mbird97x. For quite some time, I repaired designed and redesigned switchmode power supplies for large industrial application. An ESR meter is a must in that industry. When repairing an older switchmode power supply, they are finicky with the new capacitors. Some of the super low ESR caps would make very noisy (audibly) supplies. I would have to use the ESI Video Bridge we had, to evaluate the reason and choose appropriate capacitors. When designing a supply, there is more variability.... You can make newer supplies switch faster... and so on. Technology has come a long way since the TL494 :lol: Anyways, I have an older Dick Smith meter that works ok, but the true test is when you mimic the actual conditions of your powersupply. My Dick Smith meter only tests at 1kHz (Much lower than the oscillating freq imposed on the caps in a switchmode supply) Most "not all" higher ESR caps will show their problems at this freq, but If you really want to troubleshoot, you should find a meter with variable frequency control. There are some topics on the net on how to simply build one that will operate at 100kHz. This is much closer to the operating frequency than 1kHz.
I own a ESI 2100 Video Bridge, and GenRad 1689M.... (just wrote a thread on its Ram battery) These are great tools, and very accurate, but not cheap. These both have variable frequency and external bias, so you can apply voltage to the cap (other than whats supplied by the fixture itself) For the every day hobbiest, Dick Smith meters are just fine. If you want to get more serious..... Serious costs money.
Hope this helps.
PostPosted: May Sat 26, 2012 1:45 am
I'm pretty sure the Dick Smith tested at 100kHz.
PostPosted: May Sat 26, 2012 3:22 am
Maybe the newer ones do??? My Dick Smith meter only does 1 kHz. Infact most smaller ESR meters will only do 1kHz because it's just a general "Ok for all" test freq. Both the GenRad and the ESI default to 1kHz at 1000mV for general testing. All other test parameters have to be entered manually. I will look into the newer Dick Smith meters and see. That would be interesting to know.
EDIT>>>> Ok, I got out the scope, The Dick Smith meter tests at 2kHz. They claim not much has changed in their new version "Blue" except firmware to aid those building the kits. It gives you a code as to what may be wrong when the kit builder can't get it right.
PostPosted: May Sat 26, 2012 4:24 am
ESR meters, selenium rectifiers, and electrolytics in series.
RRM
PostPosted: May Sat 26, 2012 5:31 am
Both the Anatek Blue (new Dick Smith, but its been around a while) and Peak Atlas test at the "industry standard" 100 kHz. The Blue was my runner up choice over the Peak, but the non-polarized connection and protection circuitry really sold me on the Peak and its not really that much more expensive. A lot of people have damaged their Blue meters by connecting to charged caps, its a very easy thing to do on a board filled with caps and you forget to discharge them. But if used properly the Blue will get the job done.
-Mark-
My Current Projects:
http://www.facebook.com/#!/pages/Marks- ... 4487855125
PostPosted: May Sat 26, 2012 11:00 am
Ya, My Dick Smith meter must be old (well I did purchase it ages ago) Looks like the design has changed a little.... They say the new signal is sinusoidal...... This one is far from that. But it works great still. As seen on the scope, it's frequency is 2.008 kHz.
Here it is on the scope
PostPosted: May Sat 26, 2012 7:00 pm
Even 30 years or longer ago when Creative Electronics came out with what may have been the first affordable ESR meter, the unit ran at 100KHz which was changed to 50KHz when they were having problems finding IC's that would work in their circuit at the higher frequency. I don't understand why any manufacturer since that time would have thought it was OK to run the test at a substantially lower frequency.
PostPosted: May Sat 26, 2012 7:49 pm
Perhaps someone with a spectrum analyzer could check that 2-kHz pulse train from the Dick Smith ESR tester and tell us what the frequency content is.
The Pulse Repetition Frequency (PRF) may be 2-kHz, but the frequency content will extend well above that. It is the pulse width that is important here, not so much the PRF.
http://www.tarc.gvtcwebspace.net
PostPosted: May Sat 26, 2012 10:08 pm
The "Dick Smith" ESR meter is actually from Bob Parker in Australia. He licensed it out to Dick Smith Electronics until they went under. Anatek and others are now liceneced for the meter. Depending on who has it, there as some slight differences, from case (Blue for Anatek, black with a red label for a version in Portugal), to the name ("Blue ESR Meter" for Anatek, "EVB" meter for the Portugal version, etc..) to other things (The Portugal version seems to have the diode mod built in, as it handles 400V protection).
Regarding the pulse, Anatek's comparison page states for it's method:
Microcontroller with pulse - effective frequency ~ 100 Khz
In Bob's kit manual, it states:
(2). Basic Signal Generator: the
meter’s test signal is a 500mV P-P
(open circuit) burst of 8ms pulses at
a 2kHz rate, repeated several times
per second. As a result, it can be
used as a signal source for basic
checks on amplifiers, loudspeakers
and other audio components
BTW, fault codes to help the builders, were also in the "Dick Smith" version.
- Vince
PostPosted: May Sun 27, 2012 1:56 am
Great info EICOKnight. That explains the 2kHz pulses. I could not find that info anywhere. The other versions (100kHz) must then have the sinusoidal output. Both my GenRad and ESI have a beautiful sine wave at the Kelvin clips. As I mentioned earlier, both the GenRad and ESI default to 1 kHz @ 1V for general testing..... Seems to work great. So 2 kHz can't be that bad. :)
PostPosted: May Sun 27, 2012 2:11 am
The test frequency has to be high enough that the capacitive reactance is substantially lower than the ESR, since the meter is displaying the sum.
PostPosted: May Sun 27, 2012 11:01 am
Exactly. The distinction between ESR—Equivalent Series Resistance—and capacitive reactance can’t be pointed out too often, if the many discussions here of condenser testing are any indication. A standard impedance bridge will not permit the testing (as opposed to measurement) of electrolytic condensers in-circuit, which is the raison d’être of an ESR meter.
An ESR meter is in fact very useful in trouble-shooting vintage radios—vintage transistor radios. A transistor radio can be up to 58 years old now, older than a great many tube sets when they were being collected as “antiques”. And an ESR meter is virtually essential for trouble-shooting modern electronic equipment. It will save a vast amount of time.
The ideal testing frequency appears to be in the vicinity of 100 kilocycles. My own ESR tester is a home-made adapter, employing a transistor Hartley oscillator at 140 kilocycles, which is used in conjunction with a high-frequency volt-meter, usually a portable Hewlett-Packard 427A. In many years of use it has never failed to identify the bad electrolytic condensers in solid-state equipment.
On this page—
http://www.flippers.com/esrkthnt.html
—the Dick Smith ESR meter is stated to employ a 2-kilocycle train of 10-microsecond pulses at an open-circuit amplitude of 600 millivolts. This signal, shown in the picture above, is similar to the output of a blocking oscillator signal injector (albeit lower in voltage). As Ed insightfully pointed out above, because of the harmonic content of the pulses, the meter works similarly to those employing conventional waveforms at 100 kilocycles.
On this page—
http://www.anatekcorp.com/esr_compare.htm
—it can be seen that the Anatek Blue ESR meter carries over the pulse concept, and the pulse train is described as having an “effective frequency” of 100 kilocycles. There’s no mystery here, after all. Pulse waveforms like this have long been used in this way, often when it was desired that a low-cost circuit produce a signal with both an audio tone and a “radio frequency” component. I recall a 1960s White’s T-R metal detector circuit that employed a blocking oscillator in this manner. Signal injector probes have been discussed here many times.
The testing frequency is also an important factor in measuring capacitance and inductance. Small condensers and coils intended for RF circuits are best measured in the vicinity of the frequencies at which they will be used. My bench LC meter was made by Tesla in Czechoslovakia, and it works by placing the condenser or coil to be measured across a standard inductance or capacitance, respectively (different standards for the various ranges). By adjusting the measurement dial, the frequency of a VFO is swept. An amplifier and detector indicate the resonance peak on a meter. The reading is taken from the dial when the peak is located. This method of measurement insures that components are measured at appropriate frequencies. And in fact, differences in the height and sharpness of the resonance peak indicate Q, although in a relative, un-calibrated, manner. A proper Q-meter will do all of this, and indicate a value for Q as well.
PostPosted: May Mon 28, 2012 2:42 pm
HI ALL:
I AGREE WITH JOHNNYSAN. I HAVE OWNED MY EDS 88A SINCE 2004.NOW PRICED AT $200.00.
I SERVICED ALL KINDS OF ELECTRONICS AND IT HAS BEEN A REAL TIME SAVER WITH IN CIRCUIT TESTING USING A TWEEZER PROBE.YOU DO NOT HAVE TO OBSERVE POLARITY OF THE PROBE AS IT USES A AC VOLTAGE. AN ELECTROLYTIC CAN CHECK GOOD FOR CAPACITY AND LEAKAGE ON A LC METER BUT THE REAL PROBLEM IS THE ESR. A CAP MAY NOT SHOW BULGING BUT STILL HAVE HIGH ESR. I HAVE HAD TO CHANGE THE BATTERY A COUPLE OF TIMES BUT IT WAS USED EVERY DAY.IT ALSO HAS AUTOMATIC SHUT OFF TO PRESERVE BATTERY USAGE.IN SWITCHING POWER SUPPLIES I MOSTLY FIND THE SMALL CAPACITY FEEDBACK CAP THE PROBLEM SO THAT IS ALWAYS CHANGED PERIOD.SOME OF THE COMPUTER POWER SUPPLIES ARE REALLY PACKED TIGHT.NOT ALWAYS AN EASY QUICK REPAIR.THE EDS ALSO HAS A TABLE ON THE FRONT.I CANNOT SERVICE WITH OUT IT TODAY.YOU CAN FIND IT ON THE INTERNET.PLEASE TAKE A LOOK.
BEST REGARDS
WALTER-W2WIQ
PostPosted: May Tue 29, 2012 3:13 pm
Thanks to all who responded. I have chosen the blue Anatek because it is less than some of the others and does the same job. I'm sure I would have been just as happy with the Peak or the EDS, just wouldn't have lunch money for the rest of the week :lol:
Now on to learning more on these late model SMPS.
Gary
PostPosted: May Tue 29, 2012 3:58 pm
I've been lusting after a HP 4800A vector impedance meter http://www.ebay.com/sch/i.html?_nkw=hp+4800a+meter for measuring ESR :-) See the HP Journal article on it: http://www.hpl.hp.com/hpjournal/pdfs/IssuePDFs/1967-01.pdf
I may have to homebrew one. Center-zero meters are getting hard to find, though.
Best regards,
PostPosted: May Wed 30, 2012 2:20 am
Hi Mbird97x. The thread was going a little crazy with nerd raging, and I was hoping we didn't scare you away :lol: Another thing you will find handy in working with swich mode ps's...... A current probe. This will help in looking at the main switching fet or transistor under load, and how well it's turning on and off. You can get away without one, but one you have used one, it's a whole world of learning again. Good luck with your new ESR meter.
PostPosted: May Wed 30, 2012 10:53 am
I didn't get scared away. I was able to wade thru the "extreme" reccomendations. I just wanted a simple way to weed out the seemingly plentiful rash of bad electrolytics out there in the ever popular TV's and such. I luckily found a replacement PS board for my LCD tv, but maybe with an ESR meter I could have pinpointed a bad cap and not had to wait as long searching for a used pull off ebag. I didn't want to trial and error cobble something together or use a complex set-up of older scope and bridges when there is a reasonably priced unit out there already. I guess some just believe it's too simple to be good.
Gary
PostPosted: May Wed 30, 2012 2:17 pm
I second the motion regarding a current probe. One point (OK, two) - be sure to get one that can handle fast transients and moderately high peak currents if you're seriously considering working on modern switchers. Buy the "best that you can afford." :wink:
PostPosted: May Wed 30, 2012 6:33 pm
MBIRD97X
I AGREE WITH WHAT YOU DESIRE. I SILL RECOMEND THE EDS88A IF YOU CAN AFFORD THE $200.00.VERY SIMPLE & QUICK CHECKS. I'VE USED IT MOSTLY IN TV,MONITORS AND SWITCHING SUPPLIES FOR THE PAST 9 YEARS.
YOU CAN DOWNLOAD THE INSTRUCTION MANUAL AT THIS LINK UNDER CALIBRATION INSTRUCTIO DOWN THE PAGE YOU WILL FIND THE LINK.IT IS A MICROSOFT WORD DOCUMENT.WORTH READING.
http://www.eds-inc.com/eds88.html
GOOD LUCK.
WALTER-W2WIQ
