Page 1 of 1
[ 8 posts ] |
| Author |
FStephenMasek
Post subject: Determining Knight KG-686 replacement transistors Posted: Sep Mon 21, 2009 3:46 pm |
| Member |
Joined: Mar Sun 11, 2007 6:55 am Posts: 5662 Location: Mission Viejo, southern California
My Knight KG-686 signal generator is missing one transistor (never installed), and John Kusching (thanks) helped me yesterday determine that another one is bad. The bad one is marked 131, then below that, the Motorola symbol and 744. Reading the assembly manual, it seems that both should be the same part number.
_________________ Many of my radios are on my http://www.photobucket.com account - FStephenMasek.
My company website is http://www.masekconsulting.net
| Top |
Johnnysan
Post subject: Posted: Sep Mon 21, 2009 8:13 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 11441 Location: Albuquerque, NM 87123
The NTE book lists the 131 as a NTE108 which is an RF amp. The 744 crosses to an NTE128 which is an audio driver. I don't think these crosses are valid for your application.
| Top |
FStephenMasek
Post subject: Posted: Sep Tue 22, 2009 1:22 am |
| Member |
The assembly manual shows a part number of 660-131 for both transistors. That comes up as NTE123AP, a NPN audio amplifer, or switch. One of them, TR-6 on the schematic, serves in the 100kHz oscillator (internal crystal calibration section), and the other TR-2 on the schematic, serves as a E. F. (whatever that is).
| Top |
Rich, W3HWJ
Post subject: Posted: Sep Tue 22, 2009 4:19 am |
Joined: May Tue 30, 2006 4:46 pm Posts: 4783 Location: Santa Rosa, CA
Quote: below that, the Motorola symbol and 744.
In this case, "744" is most likely a date/lot code from 1974.
| Top |
Mikeinkcmo
Post subject: Posted: Sep Tue 22, 2009 11:19 am |
I'd think E.F. is simply an emitter follower.
Keeping NPN for NPN etc, have you tried subing whatever you have on hand?
Unless you are working with VHF/UHF, low noise, or power amplifier devices, there are usually a lardge number of devices that will work well. Often those substitution types are a GROSS approximation of what the original device was, and most any device will work well enough.
| Top |
FStephenMasek
Post subject: Posted: Sep Tue 22, 2009 4:54 pm |
| Member |
I don't have any transistors, so have nothing to substitute. I could take one from a pocket radio, but it works, so I'll order some from Mouser and see what happens.
| Top |
Dean Huster
Post subject: Posted: Sep Wed 23, 2009 12:52 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 3187 Location: Harviell MO USA 63945 (12 miles S of Poplar Bluff)
Quote: Often those substitution types are a GROSS approximation of what the original device was, and most any device will work well enough.
When you consider that a few hundred substitution part numbers manage to subsitute for thousands of different parts, there HAS to be a lot of compromise in many cases.
_________________ Dean, Electronics Curmudgeon Contributing editor emeritus in Poptronics magazine, R.I.P.
| Top |
ariston
Post subject: Re: Determining Knight KG-686 replacement transistors Posted: Jul Fri 13, 2012 11:25 am |
| Member |
Joined: Mar Sun 20, 2011 2:53 pm Posts: 383 Location: Spain
FStephenMasek .- Just today piked one KG-686 for rebuild. Please can you suply a manual“s copy ? correo@candiles.orgThanks
| Top |
Page 1 of 1
[ 8 posts ] |
Who is online |
Users browsing this forum: gvel and 4 guests |
