It is currently Oct Mon 15, 2018 12:00 pm
 Post subject: Ballantine 300
PostPosted: Jan Tue 10, 2017 1:12 am
Does anyone know the specified full scale deflection current for the meter movement in a Ballantine 300 (no suffix)?
I measured about 400 microamps without the meter movement cover and about 500 microamps with the meter movement cover.
Curly
 Post subject: Re: Ballantine 300
PostPosted: Jan Tue 10, 2017 2:05 am
The manual which I can send you if you don't have it says
"M1 - Special type meter can only be obtained from Ballantine"
Of course if you already have the manual, you already know this.
73, de Chuck K4CCW
"The question is not what you look at, but what you see." Thoreau
PostPosted: Jan Tue 10, 2017 4:44 am
Hello Chuck,
Thanks, I already have the manual.
This is actually a Weston #643 logarithmic meter movement, so no zero! With no input, the needle is pegged to the left side, off scale. This is normal.
I was wondering how the magnets held up after sixty years, i.e. loss of strength. So, I looked for the FS deflection spec in the manual -- not given. No doubt that some enterprising Ballantine fan has been where no man has gone before.
Curly
PostPosted: Jan Wed 11, 2017 8:44 pm
A side note. Why did Ballantine use a hand calibrated log meter movement?
http://lcweb2.loc.gov/master/mbrs/recording_preservation/manuals/Ballatince%20Electronic%20Instruments%20(catalog).pdf
Curly
Users browsing this forum: dninneman, Google Adsense [Bot], Google [Bot] and 12 guests
