It is currently May Mon 21, 2018 12:26 am
Post New Topic Post Reply  [ 33 posts ]  Go to page Previous  1, 2
 Post subject: Re: How many still use the Tek tube scopes?
PostPosted: Jan Wed 11, 2017 3:30 am
I've a working 561B, and a 564.
Been collecting plugins for them, and now have a 3L5, 3S2, 3T2, 3S7, 3T7, and a 3A5. Need to find a 3B5 at some point, to marry up to the 3A5.
I've got a basic set of amplifiers, and time bases that work fine, as does the 3L5. The samplers, and 3A5 are relatively recent additions, and need going through.
I mostly use the 561B when poking around higher voltages (read: a TV). Otherwise, I've a 2246 I use when working with relatively voltage stuff. I've got a 7603 & 7584 setting near by w/ appropriate plugins, but they almost never gets used, too big, and the 2246 is too convenient. There's also a little 211 handy, if I need something tiny, and portable.
"Hi, my name is David, and I have an oscilloscope problem." :lol:
David
PostPosted: Jan Wed 11, 2017 4:46 am
I have (in order of size) a 214, 310A, 465, 466, and a 511AD (awaiting restoration).
R/ John
PostPosted: Jan Wed 11, 2017 6:05 am
I got rid of the plug-ins I never used, but my secret weapon is the 1A7A for low level stuff. I also use the diode recovery plug-in every now and then. I've got a sampling plug-in, but have never determined if it works or how to fix it if it doesn't. I used to have the very desirable spectrum analyzer plug-ins, but concluded that with a linear time base, they're not terribly useful, so sold them off as well.
PostPosted: Jan Wed 11, 2017 6:28 am
2236 w/digital counter built in.
Very good... I got it used on Ebay I think now about 5
-7 years ago... for 300 bucks or so.
So far ... very nice, ...no problems
PostPosted: Jan Wed 11, 2017 6:31 am
I do have a bunch of tube HP scopes - 120B, 132A, and the 140A, with both standard plugins and the TDR plugin.
PostPosted: Jan Wed 11, 2017 7:09 am
I have a 2246 for the few times I ever need an XY display (my digital scope struggles there) but I prefer the functionality and user interface of my Rigol for day to day usage.
PostPosted: Jan Wed 11, 2017 12:31 pm
No counter and no storage, but my full time bench scope for almost 5 years now is a Tek 2465 a good GP scope. Paid about 300 bucks for it, and its been a nice addition.
PostPosted: Jan Wed 11, 2017 6:54 pm
pixellany wrote:
They make good heaters.....:)
Almost exactly 50 years ago, I was working in a cal lab repairing and calibrating those monsters...so I do have fond memories. Now, I would have no room for one.
Funny - we used to pull the time delay relays in the Tek 5XX's and fire them up for heat in the winter - our two wall mounted heat-pump units couldn't keep up. The Thermo-humidigraph would bottom out it was so cold. With three scopes and every other thing turned on, we could get it to a balmy 65 degrees - warm enough to calibrate!
Brian
PostPosted: Jan Wed 18, 2017 12:48 am
My 515A is the only scope that I can truly trust. Inside it looks as though it arrived from the factory yesterday. The fan bearing is a bit noisy, though. My other non-audio range scope is a 10+ years old 25 MHz Velleman PC scope with FFT spectrum analyzer. I seldom use it. With some equipment I recently built, I just mix everything down to the range of the 515A.
Ted, KX4OM
PostPosted: Jan Wed 18, 2017 1:01 pm
I use to much of them :lol:
greetings
Martin
PostPosted: Jan Wed 18, 2017 5:02 pm
I think Martin probably has to run air conditioning in the winter, too, with the collection he has! :lol:
-Pat
https://pmanning.smugmug.com/
PostPosted: Jan Wed 18, 2017 7:55 pm
a pair of triple nickel (Tek 555) is very compatible to an electric furnace.
The third will blow out the fuse from the working room..
hello Mike,
a counter can also be a plugin for the Tek :wink:
greetings
Martin
PostPosted: Jan Sat 21, 2017 8:49 am
today buyed (50,-): Tek 5113 (2mc only, but a true Dual Beam + Storage) + diff + 2ch
lG Martin
Users browsing this forum: jeffs01879, realbones and 10 guests
