It is currently Jun Sun 24, 2018 4:07 am
 Post subject: Ballantine 300
PostPosted: Jan Tue 10, 2017 1:12 am
Does anyone know the specified full scale deflection current for the meter movement in a Ballantine 300 (no suffix)?
I measured about 400 microamps without the meter movement cover and about 500 microamps with the meter movement cover.
Curly
 Post subject: Re: Ballantine 300
PostPosted: Jan Tue 10, 2017 2:05 am
The manual which I can send you if you don't have it says
"M1 - Special type meter can only be obtained from Ballantine"
Of course if you already have the manual, you already know this.
*** Wanted: Hallicrafters S-76 ***
Chuck K4CCW
PostPosted: Jan Tue 10, 2017 4:44 am
Hello Chuck,
Thanks, I already have the manual.
This is actually a Weston #643 logarithmic meter movement, so no zero! With no input, the needle is pegged to the left side, off scale. This is normal.
I was wondering how the magnets held up after sixty years, i.e. loss of strength. So, I looked for the FS deflection spec in the manual -- not given. No doubt that some enterprising Ballantine fan has been where no man has gone before.
Curly
PostPosted: Jan Wed 11, 2017 8:44 pm
A side note. Why did Ballantine use a hand calibrated log meter movement?
http://lcweb2.loc.gov/master/mbrs/recording_preservation/manuals/Ballatince%20Electronic%20Instruments%20(catalog).pdf
Curly
Users browsing this forum: azenithnut, Pbpix, stevebyan, xwarp and 11 guests
