It is currently Feb Thu 22, 2018 12:19 am
 Post subject: Sencore PR57 Powerite
PostPosted: Jan Wed 11, 2017 4:16 pm
I have a sencore pr57 powerite and the led's on the display meter do not work? The unit powers up and the variac :( section works good. The schematic shows only CR201-CR204 Part 20G18 but that it? Has anyone run into this problem?
 Post subject: Re: Sencore PR57 Powerite
PostPosted: Jan Thu 12, 2017 2:55 am
I've got several PR57s. Had a few of the leds burned out. I've just replaced them with no problems.
Alan
PostPosted: Jan Thu 12, 2017 2:16 pm
I checked the foil side of the pc board and found burnt spot where the AC switch was and a break in foil next to the switch? I don't know what caused it to burn out 4 leds but maybe 1 switch got stuck while the other was pressed in? I repaired the foil, cleaned up the board and going to change the leds but do you know if the switches can be cleaned with Deoxit :D or other contact cleaners?
