It is currently Jul Sun 22, 2018 6:01 am
Post New Topic Post Reply  [ 22 posts ]  Go to page Previous  1, 2
 Post subject: Re: Meter shunt value quesiion.
PostPosted: Dec Wed 06, 2017 8:33 pm
Be careful in using a switch to go between shunts for different ranges. If the switch is open when between ranges then......
Better to have the two shunts in series then a switch to short out the high current shunt leaving the low current shunt in circuit. I have used just a push button in the past.
Cheers - Martin ZL2MC
PostPosted: Dec Wed 06, 2017 9:13 pm
TPAairman wrote:
With a 3 amp meter, the -0-1 amp section is not very big, meaning that the 100's of mA can be a very small section. So doing it this way, I have a higher resolution to my meter.
Compression of the low end of the AC current scale is normal.
That's why I used a spring-return toggle switch to drop the range to the meter's native 0.5 amps.
One resistor + a toggle switch is a heck of a lot cheaper than the added circuitry suggested.
In this situation, a 2.5A shunted range would make more sense than a 3A range.
With 2.5A FS, you just multiply each major scale division by 5 to get the true value.
- Leigh
73 de W3NLB
http://www.AtwaterKent.info
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot], TechyMechy and 10 guests
