It is currently Jul Sat 21, 2018 1:23 am
 Post subject: Hickok 752 Tube tester
PostPosted: Dec Fri 01, 2017 5:38 am
Recently picked this up.
Cleaned controls, had a 5V4 inside with 5Y3.
Changed to good testing 5Y3 and 83.
Turns on, meter jumps all over and sometimes doesn't come up.
Otherwise, looks like it WANTS to test a good 12AX7 ok.
Comes up sometimes.
Any advise on where to start?
Tks.
 Post subject: Re: Hickok 752 Tube tester
PostPosted: Dec Fri 01, 2017 3:19 pm
sounds like dirty switches or socket pins could cause that intermittent action. Great tester, good luck.
_____________________
Bruce
PostPosted: Dec Fri 01, 2017 7:48 pm
I have one as well. Great tester. Don't go overboard with the contact cleaner.
Joel Walker
Professional Thread Killer
PostPosted: Dec Fri 01, 2017 8:42 pm
Start with the ac connection, can you do a "line adjust" ok?
Joe @ Vintage Test Equipment - There's no shortage of cruelty to animals: http://joinASPCA.org
PostPosted: Dec Sat 02, 2017 3:33 pm
How did it happen to have a 5V4 and a 5Y3 in it? 5V4 is an octal tube, no sub for 83 which has a 4-prong base.
If somebody made up a socket adapter it might have worked--but not very well--and no big deal to switch it back to the correct tube. Then one could go after the usual Hickok 'suspects' like dirty switches and controls, and the electrolytic across the meter.
But if somebody changed the tube socket it would indicate tinkering occurred in the past. Then anything could be going on.
Thomas A. Edison
PostPosted: Dec Sat 02, 2017 3:51 pm
Just curious, did you recap it? My 752A had 5 caps - 2 electrolytic caps and three paper caps.....
Brian
PostPosted: Dec Mon 04, 2017 5:15 pm
Just a suggestion-- as you work your way through this tester you should use a different tube type to measure your results. 12AX7's invariably test low on the Hickok's (and probably many other brands of tube testers) and you may be mislead by erroneous test results. 6L6's are used as the "calibration" tube for these testers.
Terry
"Hardware eventually fails. Software eventually works" - Michael Hartung
Users browsing this forum: keith49vj3 and 10 guests
