It is currently Feb Thu 22, 2018 7:57 am
 Post subject: RCA WV-97A Senior VoltOhmyst VTVM How the heck do you get in
PostPosted: Dec Sat 09, 2017 5:15 am
How the heck do you get in to work on a WV-97A?
I’m also working on some Heathkit VTVMs – an IM-11, IM-13, and an IM-28. For these, it was easy to drop everything from the front panel and thus gain access to the range and function switches and their associated components.
But on the WV-97A, I had to start desoldering connections just to get the range switch disengaged from the front panel. I still can’t reach most of the components. What’s the secret to working on these?
 Post subject: Re: RCA WV-97A Senior VoltOhmyst VTVM How the heck do you ge
PostPosted: Dec Sat 09, 2017 8:40 pm
Update: Well, I had thought the chassis was spot-welded to the front panel, but as soon as I removed the control nuts for the DC Zero and Ohms Adjust, the chassis dropped away. :oops:
PostPosted: Dec Sun 10, 2017 4:09 pm
when faced with insurmountable or inscrutable situations in accessing old equipment's innards, I always reach for the sawzall or 16lb sledge...........in a pinch, a plasma cutter will do :-D
He who dies with the most sheer tonnage of ancient test gear, wins!
Users browsing this forum: Google [Bot] and 7 guests
