It is currently May Thu 23, 2013 12:08 am
 Post subject: Jackson 658-A meter broken
PostPosted: Jun Thu 06, 2002 11:45 pm
I need a new/used meter for the Jackson 658-A tube tester. I broke the sping inside trying to remove corrosion.Any old dead 658's or 658-A's out there? Suggestions on replacing with other meter and settings?How are meters set,in millamps?<BR>Mike<BR><P>------------------<BR>
PostPosted: Jun Sun 09, 2002 4:54 am
Bummer. 658s are rare; spare 658 meters even more so. The parts list is very helpful: it says "Meter." Can you piece together the old meter, even long enough to measure the sensitivity? 1 mA would be a good guess to start, but to really find out, you can substitute a Simpson 260 or other VOM and see what it reads. Jackson didn't make its own meters, so if you search long enough, you can find a movement that will fit.<P>------------------<BR>
PostPosted: Jun Mon 10, 2002 11:18 pm
I'll try to put spring back together to measure ma.Where can I get Simpson 260? Any other areas to search?<P>Mike<P>------------------<BR>
PostPosted: Jun Mon 10, 2002 11:54 pm
The links on the search page don't work.Any help?<P>Mike<P>------------------<BR>
Users browsing this forum: baird, Chris108, Lou deGonzague, tanglong2009 and 1 guest
