It is currently Apr Sun 30, 2017 7:45 pm
 Post subject: Help identifying magnavox console and needle
PostPosted: Apr Thu 20, 2017 5:12 am
Hi - I'm trying to identify the year of a magnavox phonograph and radio console we have. The serial and model numbers are ripped off so I am unable to identify it that way. The unit needs a new needle, but I'm big sure which one to look for since I don't even know the model number. I've attached photos. Any help would be appreciated!
 Post subject: Re: Help identifying magnavox console and needle
PostPosted: Apr Thu 20, 2017 5:25 pm
Location: South of Richmond, VA 25 miles down the pike.
Model numbers only help to the extent someone else may have same model and can fill you in with details. Or some previous serviceman has the data, or some brochure helps. Take the back off and look for chassis numbers. Little white labels with R214-???? or what. Some are stamped in/on the metal. These get to the documentation you may need if you are going to upgrade/fix you set. The record changer will have numbers on labels underneath, stick in your head or use a mirror to get these because it will need to be cleaned and lubed again.
Bill J.
PostPosted: Apr Fri 21, 2017 1:54 am
1969 Astro-Sonic Series 200, model 3633, in a Mediterranean cabinet.
Information can be found at this link. You'll need to join but it's free:
http://vintagehifi.net/index.php
kb3wbb
PostPosted: Apr Fri 21, 2017 2:04 am
For your stylus, you can find one here
http://thevoiceofmusic.com/catalog/phono_needles.asp
use the search for by phono brand "Magnavox"
Gary at Voice of Music. com can help you and he has reasonable prices!
Hope this helps
PostPosted: Apr Fri 21, 2017 4:54 am
Thanks everyone. I found the model no. and serial no.
Model No: 1P3633
Finish: PECN
Serial No.: 4326113
Run No: 2
I'm still trying to find the correct needle number.
Post New Topic Post Reply  [ 5 posts ]  Moderator: Alan Voorhees
