It is currently Dec Wed 13, 2017 4:52 am
 Post subject: Newly purchased/refurbished Webcor Ravinia has a problem
PostPosted: Dec Mon 04, 2017 7:05 pm
Hello,
Can you please help diagnose the problem with my newly refurbished Webcor Ravinia. I was just playing it now and all of a sudden the signers voice got very wobbly sounding and the record speed off and I can hear a very light clicking from under the player. Thoughts?
 Post subject: Re: Newly purchased/refurbished Webcor Ravinia has a problem
PostPosted: Dec Mon 04, 2017 8:12 pm
Idler wheel shed a patch of rubber? Maybe a bit of lube migrated onto the idler wheel rim? Should be fairly easy to pull the platter and investigate.
PostPosted: Dec Mon 04, 2017 9:27 pm
Yeah, checked the idler wheel which is new and seems fine. Seems to be getting worse. Just tried a record again and the platter barely even spins now. All parts seem very well lubed.
PostPosted: Dec Tue 05, 2017 10:35 pm
1. Can you see the motor turning when idler wheel
is pulled away from rotor ?
2. Have you removed and rebuilt/cleaned the motor ?
Old oil/lubricant once heated up by motor friction can
appear. Either bond to bearings and slow the
motor, or liquefy and come out on idler, et cetera.
This is not uncommon even when the motor has
been cleaned, if the bearings were not soaked
in solvent to loosen/wick out the old lubricant.
3. Were the motor mounts changed out with
new ones ?
Hotwax
PostPosted: Dec Thu 07, 2017 6:15 am
Umm...crazy it started working again on it's on. So I'm going to monitor it and see what happens.
PostPosted: Dec Thu 07, 2017 6:16 am
Deleted
Users browsing this forum: jeffs01879, ndiamone, PeterT and 10 guests
