Page 1 of 1
[ 12 posts ] |
| Author |
Bones007
Post subject: 1960's Zenith Console Phono Posted: Jan Sat 07, 2012 9:46 pm |
| Member |
Joined: May Sun 08, 2011 8:52 pm Posts: 168 Location: Bay City Mi
Hi All , I got this from a buddy who was going to put this beauty out to the road. it is a Model SL2505 I think it is from 1963. It plays great except on AM all it does is motorboat , I have replaced the electrolytics on it only. My Jackson 648 does not have a listing for the receiver tubes so I can't test them. Cannot find a schematic on line. The FM and phono play Great! would a tube cause the motorboat just on AM only? Any help is appreciated. Thanks
| Top |
Ken G
Post subject: Re: 1960's Zenith Console Phono Posted: Jan Sun 08, 2012 3:36 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 14582 Location: ID 83301
Yes a tube could cause it , also a capacitor or resistor could
| Top |
RepairTech
Post subject: Re: 1960's Zenith Console Phono Posted: Jan Sun 08, 2012 3:39 am |
| Member |
Joined: Jan Sun 24, 2010 7:59 am Posts: 6171 Location: Pro Tech, Philadelphia Pa.
Bones007 wrote: Hi All , I got this from a buddy who was going to put this beauty out to the road. it is a Model SL2505 I think it is from 1963. It plays great except on AM all it does is motorboat , I have replaced the electrolytics on it only. My Jackson 648 does not have a listing for the receiver tubes so I can't test them. Cannot find a schematic on line. The FM and phono play Great! would a tube cause the motorboat just on AM only? Any help is appreciated. Thanks  Most likely the AGC cap is bad, along with any other paper caps.
_________________ "Accept the fact that some days you are the pigeon, and some days you are the statue."
| Top |
Fred Longworth
Post subject: Re: 1960's Zenith Console Phono Posted: Jan Sun 08, 2012 7:40 am |
Joined: Jun Fri 22, 2007 12:54 am Posts: 682 Location: San Diego
I agree with Repair Tech. Check the AGC cap. Also, check for high-value resistors in the AGC circuit that have begun to open up. Also, check for loose or poorly-soldered grounds. The nature of FM is such that poor filtering in the power supply will be less likely to induce "motorboating" than in a similar AM stage.
And do find a tube checker. Some TV shop in your town should have one. Tubes from the early 1960's are very common. At my repair shop, when someone brings in a set made in 1963, nearly always there are a couple of bad tubes.
Fred repairing audio gear since the Pleistocene
_________________ www.repairaudio.com
| Top |
Bones007
Post subject: Re: 1960's Zenith Console Phono Posted: Jan Sun 15, 2012 7:51 pm |
| Member |
Well , I had the story backward , that's what I get for working on several at a time, I fired it up again and it is the AM that is dead , and the FM motorboats. There is only 1 paper cap under the chassis, the rest are disc type, the tube compliment is as follows 1-12TD8 , 2- 12BA6, 1- 12AU6, 1-12BE6, 1-19GQ7, and the 35W4. my tester does not have settings for the 19GQ7 , others test OK. I do not have a spare 19GQ7 so I will order another just to try. But other than that , has anyone come across a radio with similar problem like this? Any suggestions are appreciated. Thanks
| Top |
oldmusicman
Post subject: Re: 1960's Zenith Console Phono Posted: Jan Sun 15, 2012 8:28 pm |
| Member |
Joined: Jul Sun 31, 2011 6:19 pm Posts: 1787 Location: Kitchener Ontario Canada (left UK 2007)
Could be a bad tube. Also it maybe a cap, just because they are disk type doesnt mean they dont go bad, remember that unit is pushing 50 years old. Am totally dead good be a bad rf coil, u need to get out a meter and do some checking.
_________________ Zenith "The Quality Goes In Before The Name Goes On"
| Top |
Ken G
Post subject: Re: 1960's Zenith Console Phono Posted: Jan Fri 20, 2012 9:16 am |
has anyone come across a radio with similar problem like this? Any suggestions are appreciated. Gee wizz ..... after all of us mentioned a capacitor or resistor or tube would cause that , how else can we help you  Maybe if you rifinish the cabinet it would fix it .
| Top |
electra225
Post subject: Re: 1960's Zenith Console Phono Posted: Jan Sat 21, 2012 1:59 am |
Joined: Dec Sat 23, 2006 5:49 pm Posts: 837 Location: san tan valley, az
GREAT answer, Ken! Putting a doily on top for the cat to sit on would help, too...........GREG
_________________ Always be yourself. Everybody else is already taken.
| Top |
Bones007
Post subject: Re: 1960's Zenith Console Phono Posted: Jan Sun 22, 2012 2:50 am |
| Member |
Yea how could I be so stupid ... sure it could be a resistor, tube or cap or even a coil! I'm sure one of these items is the cause of every radio not working, DUH!!! I just thought someone may have come across this same problem and might pass along what they found , thought it might narrow it down to a particular stage or something .... sorry for pissing everyone off!
| Top |
oldmusicman
Post subject: Re: 1960's Zenith Console Phono Posted: Jan Sun 22, 2012 2:33 pm |
| Member |
Next time i dont think i will bother answering.
| Top |
Bones007
Post subject: Re: 1960's Zenith Console Phono Posted: Jan Sun 22, 2012 6:02 pm |
| Member |
As I said Sorry, my reply was directed at the sarcasm, I have no experiance in FM sets , someone mentioned the AGC cap , which I appreciate, trouble is with no schematic I don't know where to find it , as I said all the caps are disc type , and are only color coded , none show any obvious shorts or leakage. I did find a resistor that had went up in value from 33k to almost 100k on the plate of the 19GQ7 tube , but did not seem to make a difference. So I guess my next step will be to refinish and put a doiley on top as suggested Thanks
| Top |
RWood
Post subject: Re: 1960's Zenith Console Phono Posted: Jan Tue 24, 2012 4:11 am |
Joined: Dec Tue 09, 2008 9:54 pm Posts: 151 Location: Virginia
Not sure if this helps you but here is the schematic for the L701 tuner; it also uses a 19GQ7 tube. Different overall tube lineup than yours but maybe this gets you a little closer. This tuner was paired with a solid state amplifier. I recently had and sold one of these. Dang, I can't upload the .pdf but here is where you'll find it, in the 1965 Beitman's manual. You'll need the djvu plugin http://makearadio.com/beitmans/files/1965.djvu
| Top |
Who is online |
Users browsing this forum: No registered users and 2 guests |
