It is currently Apr Thu 19, 2018 10:54 am
 Post subject: Juliette Air Suspension Speakers.
PostPosted: Jan Mon 23, 2012 2:34 am
Got a pair of these for a couple of $ there is no manufacturer on them at all apart from "Juliette Air Suspension" on the front.
They are very late 1960s early 1970s looking speakers a bit ugly if im honest, i just got them because i like to keep some cheap speakers to use as replacements if i ever need them.
They have an RCA jack in the back as a connector, so i thought id give them a try, i was amazed at the bass response on some my Bert Kaempfert tracks, really low bass.
They are not paticularly powerful but what they do produce is a lot bigger than there size.
Any of you knowledgeable guys seen these before, know who made them, or if they where shipped with a system?
I wont be tearing them apart im going to repair one of the cabinets, need to be repinned in a corner and glued, then given a proper clean.
i can see me using them quite a bit as ugly as they are.
 Post subject: Re: Juliette Air Suspension Speakers.
PostPosted: Jan Mon 23, 2012 2:52 am
Juliette was a brand of some of the cheapest crap package stereo systems that were on the market. Made Electrophonic look good. Usually made in Japan by the lowest bidder.
Brian McAllister
Sarasota FL
http://oldtech.net
PostPosted: Jan Mon 23, 2012 3:05 am
I kind of knew you where going to say that, thanks for being honest
PostPosted: Jan Mon 23, 2012 3:06 am
I have a set nearly identical to those, except mine have the "horn" design where the tweeters are both at the top and bottom where yours have only has them on the top. I am also surprised how good the sound hooked up to my JVC tabletop that I just put a new Audio Technica cartridge in. Decent bass and fairly crisp highs. They are kind of ugly though. :roll:
PostPosted: Jan Mon 23, 2012 3:33 am
Yep they are ugly :) but i like the sound.
PostPosted: Jan Mon 23, 2012 5:22 am
I had a pair of those speakers that went with a mid '70's "all in one" 8-track/radio/record changer combination. I think that name appeared on cheap imported electronics in the early '60's and I don't recall seeing anything newer than the early '80's that carried that brand name. I have a 5 tube Juliette AM radio from the mid '60's and it's one of those cheap Japanese jobs that was sold under a million different brand names.
Those speakers are about as good as any other similar cheap speaker that came with an "all in one" system and they should do OK on a low powered amp; however, I've never had a Juliette stereo that performed very well.
