Page 1 of 1
[ 11 posts ] |
| Author |
RoamingRose
Post subject: Magnavox Imperial? Posted: Mar Fri 02, 2012 7:58 pm |
Just picked a Magnavox system. Radio works beautifully, phonograph is having some issues. Turntable starts to spins, but suddenly stops and needle arm does not move on it's own or lower... Would love any help with trouble shooting this... Thanks, Casandra (won't allow me to upload pics here..can see at address below) http://www.facebook.com/media/set/?set= ... 1205f02f09
| Top |
rocketeer
Post subject: Re: Magnavox Imperial? Posted: Mar Fri 02, 2012 9:31 pm |
| Member |
Joined: Mar Tue 30, 2010 2:24 am Posts: 5144 Location: Lehighton, PA.
| Top |
RoamingRose
Post subject: Re: Magnavox Imperial? Posted: Mar Fri 02, 2012 9:35 pm |
Thank you so much for posting those pics. Hopefully now I can get some help. I have been running into brick walls with trying to find info on this system/phonograph.
| Top |
johnS.
Post subject: Re: Magnavox Imperial? Posted: Mar Fri 02, 2012 10:34 pm |
| Member |
Joined: Apr Tue 25, 2006 5:51 am Posts: 3514 Location: South Central, PA
One comment I have on this. If that's the original radio in there (and it probably is), then why would they place the dial numbers and lettering sideways like that? Just sayin'.... Here's one more picture....
_________________ -John S. In Memory Of: Curt Reed, and also Bill ("oldradiospook"). We miss you guys!
| Top |
RoamingRose
Post subject: Re: Magnavox Imperial? Posted: Mar Fri 02, 2012 10:50 pm |
I honestly have no idea if its a original radio or not. I have having EXTREME difficultly locating info on this system. But original or not, radio works great and for $5.00 I'm not complaining....Just wish I could get phonograph re-working
| Top |
johnS.
Post subject: Re: Magnavox Imperial? Posted: Mar Fri 02, 2012 11:15 pm |
| Member |
Casandra,
That's a great deal for $5.00!
I must say, though...if you are running the radio and amplifier with original parts inside, you risk more than having problems with only the turntable. With a unit this old (at least 45-50 years old), it's really a must that you have the radio and amplifier serviced. Running it with the original parts inside is very risky. Doing so could cause the power transformer to short out, and that may cause a fire. Trying to find a new transformer could also prove to be not easy, and may be expensive.
The good news is that once you have everything serviced, this will be a fine system! Bottom line...if you haven't gotten the radio and amplifier serviced, that should be done first. Then worry about the turntable after that.
Good luck!
| Top |
RWood
Post subject: Re: Magnavox Imperial? Posted: Mar Sat 03, 2012 12:26 am |
Joined: Dec Tue 09, 2008 9:54 pm Posts: 151 Location: Virginia
RoamingRose wrote: having EXTREME difficultly locating info on this system. Remove the back panel (use a quarter-inch nut driver) and either take some pictures or give us the chassis numbers on the amplifier (mounted in the bottom of the cabinet) and the tuner/preamp (mounted above). We'll tell you what you've got. RWood
| Top |
ggregg
Post subject: Re: Magnavox Imperial? Posted: Mar Sat 03, 2012 12:28 am |
Joined: Aug Sun 01, 2010 1:12 am Posts: 5226 Location: Minnesota
The sideways dial is normal on those early low consoles. Don't know if they had lots of the older dial glass left over or not but they were like that for a little while before they switched.
| Top |
Stevel
Post subject: Re: Magnavox Imperial? Posted: Mar Sat 03, 2012 12:30 am |
Joined: Nov Sat 13, 2010 5:00 am Posts: 511 Location: Woodinville, WA 98072
johnS. wrote: One comment I have on this. If that's the original radio in there (and it probably is), then why would they place the dial numbers and lettering sideways like that? Just sayin'.... Magnavox used that tuner on a number of models, and yes, decided to mount it in the Imperial even though it is sideways! It is the original tuner. Steve
| Top |
Ken Doyle
Post subject: Re: Magnavox Imperial? Posted: Mar Sat 03, 2012 2:50 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1542 Location: Haledon NJ USA
I agree that the radio & amplifier should be serviced at this age, as should the record changer, but I'd like to point out that the 45 rpm spindle with the unit is the wrong one for your record changer. You have a Collaro record changer and that 45 rpm spindle is for a VM record changer.
Ken D.
| Top |
Eric H
Post subject: Re: Magnavox Imperial? Posted: Mar Sat 03, 2012 2:56 am |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 5671 Location: Redlands CA
That changer uses two tires under the turntable, one to run the table the other to operate the reject system.
If they both stop at the same time then something is probably binding up and stopping the motor. Very possible the motor itself needs cleaned and lubed.
It's easy enough to remove the retaining clip and lift the turntable off to have a look.
| Top |
Who is online |
Users browsing this forum: No registered users and 1 guest |
