Page 1 of 1
[ 18 posts ] |
| Author |
MaryAntoinette
Post subject: What are MUST HAVES for your workstation? Posted: Apr Tue 03, 2012 9:46 pm |
| Member |
Joined: Mar Mon 19, 2012 8:20 pm Posts: 254 Location: Denver, Colorado
When working on a phonograph...what must you absolutely have readily available at YOUR workstation? Obviously a Soldering Iron or Soldering Gun, Flux, and Solder. What else? Any tips or hints for a newbie who may not have the common sense regarding this hobby to know that you need "so and so" or "whatchamacalit" would be greatly appreciated. TIA!!! *MaryAntoinette*
| Top |
Ken Doyle
Post subject: Re: What are MUST HAVES for your workstation? Posted: Apr Tue 03, 2012 11:27 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1542 Location: Haledon NJ USA
A good pair of needle nose pliers A good small wirecutter A solder sucker A multimeter Ashtrays for holding the parts. A bottle of turbine oil (Zoom Spout Oil) Light grease Aside from the usual screwdrivers, you may want a cheap set of jeweler's screwdrivers. For cleaning record changer parts you can use a can of lighter fluid, some clean rags, and some Q-Tips. For cleaning the rubber parts you can use isopropyl alcohol. Do not use rubbing alcolol because sometimes it has oil in it. Ken D. Attachment:
| Top |
electra225
Post subject: Re: What are MUST HAVES for your workstation? Posted: Apr Tue 03, 2012 11:45 pm |
Joined: Dec Sat 23, 2006 5:49 pm Posts: 837 Location: san tan valley, az
Good list. Additionally, I might suggest a can of WD-40, lacquer thinner, and a jig of some type for holding a changer so that it can be tested and serviced. Good luck...........GREG
_________________ Always be yourself. Everybody else is already taken.
| Top |
pixellany
Post subject: Re: What are MUST HAVES for your workstation? Posted: Apr Tue 03, 2012 11:46 pm |
Joined: Jul Mon 26, 2010 8:30 pm Posts: 5386 Location: Annapolis, MD
I'll take exception to the part about lighter fluid----there are lots of solvents that are not flammable. I start with isopropyl alcohol for everything---then lacquer thinner or acetone---then MEK---then maybe a mild acid. And--if you have a way of being sure that things get thoroughly dry, there's good old soap and water. For the last 60+ years, I have acquired tools based on a simple rule--buy as needed, when needed. As with many things, if you do not know WHY you need it, then you probably don't.... The other iron-clad rule: If you << lose, give away, or sell at a yard sale >> a tool, you will need it the next day---at the latest...
_________________ "It's always something". --Gilda Radner "100%" on E-Bay is not IQ......
| Top |
Doug VanCleave
Post subject: Re: What are MUST HAVES for your workstation? Posted: Apr Wed 04, 2012 11:45 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 3523 Location: Berkley, Michigan
A soldering iron is easier to use than a gun. Keep a damp sponge handy to keep the tip clean. A gun is useful when soldering to a chassis where more heat is required. Solder-Wick de-soldering braid is a good alternative to a hiss-pop solder sucker. It does a cleaner job. When I worked for a high end audio repair company with ten benches, nine out of ten techs preferred solder-wick and we made fun of the one guy that didn’t. pixellany wrote: I'll take exception to the part about lighter fluid----there are lots of solvents that are not flammable. I start with isopropyl alcohol for everything---then lacquer thinner or acetone---then MEK... Solvents should evaporate completely and leave no residue or odor. Lacquer thinner is very flammable but it is very effective in removing grease and oil. It will also melt paint and some plastics, Bakelite excluded. It leaves no residue or odor. Naphtha is another milder solvent that makes alcohol unnecessary. It evaporates quickly and completely and will not harm most rubber, paint or plastic. WD-40 is a bomb in a can that belongs out in the garage. It’s a Water Displacement product with solvents too aggressive for electronics. It is not a high quality lubricant. It stinks like dirty old machinery and the smell does not go away from whatever you use it on. Lighter fluid is similar, save that for your Zippo.
_________________ That warm tube sound can usually be overcome by turning up the treble.
| Top |
pixellany
Post subject: Re: What are MUST HAVES for your workstation? Posted: Apr Wed 04, 2012 11:50 am |
Doug VanCleave wrote: . Lacquer thinner is very flammable Hmmmm---I'm not remembering a warning on my last can of lacquer thinner-----is it as flammable as lighter fluid, charcoal lighter, or such?
| Top |
Doug VanCleave
Post subject: Re: What are MUST HAVES for your workstation? Posted: Apr Wed 04, 2012 12:52 pm |
The MSDS data sheet shows the flash point of lacquer thinner at +2 degrees F. Ronson lighter fluid is less flammable at +4 degrees F. Check this out. http://www.dosha.org/msds/Lacquer%20Thinner.pdf
| Top |
MaryAntoinette
Post subject: Re: What are MUST HAVES for your workstation? Posted: Apr Wed 04, 2012 4:01 pm |
| Member |
Thanks for the input, everyone!
Seems like I already have everything I need!
One question though...I thought Zoom Spout Turbine Oil was for lubing....what do I need a light grease for? and what kind would I need?
Thanks!
_________________ LOVE & LIGHT! *MaryAntoinette*
You can take the Girl out of Brooklyn...
| Top |
dberman51
Post subject: Re: What are MUST HAVES for your workstation? Posted: Apr Wed 04, 2012 4:22 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2308 Location: Boston, MA USA
On Ronsinol lighter fluid: Note the packaging indicates "Contains Naptha." To the best of my knowledge, it more than contains Naptha, it IS Naptha.
If you only need a small quantity (one phono) you can buy Ronsinol at the pharmacy, but I have found it so useful for cleaning any mechanical device (it's great for tape recorders and movie projectors) that I've found it much cheaper to buy Naptha in larger quantities at Home Depot.
-David
| Top |
metzman
Post subject: Re: What are MUST HAVES for your workstation? Posted: Apr Wed 04, 2012 5:07 pm |
Quote: One question though...I thought Zoom Spout Turbine Oil was for lubing....what do I need a light grease for? and what kind would I need? Check out the "best lube for phonograph" thread about three pages back in this section.
| Top |
MaryAntoinette
Post subject: Re: What are MUST HAVES for your workstation? Posted: Apr Wed 04, 2012 5:49 pm |
| Member |
Thanks, metzman! Read the thread and took some notes.
| Top |
Doug VanCleave
Post subject: Re: What are MUST HAVES for your workstation? Posted: Apr Wed 04, 2012 6:29 pm |
dberman51 wrote: On Ronsinol lighter fluid: Note the packaging indicates "Contains Naptha." To the best of my knowledge, it more than contains Naptha, it IS Naptha.
If you only need a small quantity (one phono) you can buy Ronsinol at the pharmacy, but I have found it so useful for cleaning any mechanical device (it's great for tape recorders and movie projectors) that I've found it much cheaper to buy Naptha in larger quantities at Home Depot. You might be surprised, Ronsonol Lighter fuel is 30% Hydrotreated Light Naphtha and 70% Light Hydrotreated Distillate (turpentine). It's more fat and oil than solvent. It leaves an oily residue behind. Cooking oil will dissolve glue residue from stickers, price tags and warning labels.
| Top |
dberman51
Post subject: Re: What are MUST HAVES for your workstation? Posted: Apr Wed 04, 2012 10:29 pm |
Yuck, if that's the case, don't use it. Use the real stuff from Home Depot.
-David
| Top |
Doug VanCleave
Post subject: Re: What are MUST HAVES for your workstation? Posted: Apr Wed 04, 2012 10:40 pm |
The oil in the fluid makes the metal parts look clean and shiny. That's great but it's not the best thing for turntable rims, motor pulleys and idler wheels where good grip is essential.
| Top |
Larry Hillis
Post subject: Re: What are MUST HAVES for your workstation? Posted: Apr Thu 05, 2012 12:09 am |
| Moderator |
Joined: Apr Wed 09, 2008 3:37 am Posts: 9665 Location: Little Rock, Arkansas
Doug VanCleave wrote: Solder-Wick de-soldering braid is a good alternative to a hiss-pop solder sucker. It does a cleaner job. When I worked for a high end audio repair company with ten benches, nine out of ten techs preferred solder-wick and we made fun of the one guy that didn’t. Doug, where do you get this stuff?
| Top |
Ken Doyle
Post subject: Re: What are MUST HAVES for your workstation? Posted: Apr Thu 05, 2012 12:24 am |
Doug VanCleave wrote: The oil in the fluid makes the metal parts look clean and shiny. That's great but it's not the best thing for turntable rims, motor pulleys and idler wheels where good grip is essential. I agree, I would never clean the drive surfaces with the lighter fluid, but the can is very convenient for squirting into rags or onto Q-tips. I've also had good results cleaning up the chassis paint with a little lighter fluid on a rag. Ken D.
| Top |
Doug VanCleave
Post subject: Re: What are MUST HAVES for your workstation? Posted: Apr Thu 05, 2012 1:53 am |
moses_007 wrote: Doug VanCleave wrote: Solder-Wick de-soldering braid is a good alternative to a hiss-pop solder sucker. It does a cleaner job. When I worked for a high end audio repair company with ten benches, nine out of ten techs preferred solder-wick and we made fun of the one guy that didn’t. Doug, where do you get this stuff? Larry, It's fairly easy to find. It's also called chem-wik. The heavier braid is good for old point to point connections. I always push the braid together to expand it a bit. It makes it hold more solder. http://www.parts-express.com/wizards/se ... older+wick
| Top |
Brian McAllister
Post subject: Re: What are MUST HAVES for your workstation? Posted: Apr Fri 06, 2012 10:17 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2555 Location: Sarasota FL USA
Doug VanCleave wrote: moses_007 wrote: Doug VanCleave wrote: Solder-Wick de-soldering braid is a good alternative to a hiss-pop solder sucker. It does a cleaner job. When I worked for a high end audio repair company with ten benches, nine out of ten techs preferred solder-wick and we made fun of the one guy that didn’t. Doug, where do you get this stuff? Larry, It's fairly easy to find. It's also called chem-wik. The heavier braid is good for old point to point connections. I always push the braid together to expand it a bit. It makes it hold more solder. http://www.parts-express.com/wizards/se ... older+wickAbout 50 years ago, when I worked for Mincom/3M in L.A. area, solder wick was not commercially available. We made our own, soaking braid, taken from co-ax cable, in rosin flux. Shrink tubing was also not available, so we soaked pieces of Temflex 105 tubing in lacquer thinner, (or MEK) until it expanded. When the pieces dried out, they would shrink back to the original size.
_________________ Brian McAllister Sarasota FL http://oldtech.net
| Top |
Who is online |
Users browsing this forum: No registered users and 1 guest |
