It is currently May Wed 22, 2013 9:26 am
 Post subject: Sound problem.
PostPosted: Apr Sun 08, 2012 5:55 pm
So I have a 1966 ish GE console.
When I first turn it on, the speakers sound great.
The more I listen to it, the weaker the left one gets then eventually sounds like a bunch of static.
Any help would be great on where I should start.
I initually thought the CAP on the speaker itself when it was getting weak, but now I think not with the static thing.
Thanks in advance.
PICTURE OF WHAT THE INSIDES LOOK LIKE:
HERE IS PICTURE OF THE TUNER AND CONTROLS:
 Post subject: Re: Sound problem.
PostPosted: Apr Sun 08, 2012 7:44 pm
I collect solid state consoles, sounds like a bad transistor to me, you need to check the output transistors.
If you find it is this replace the output capacitors as a precaution.
PostPosted: Apr Mon 09, 2012 6:29 am
I agree on a bad transistor that's showing off after it warms up. A can of freeze spray may help you find the defective component. It could also be a bad cap.
Post New Topic Post Reply  [ 3 posts ]  Moderator: Larry Hillis
