It is currently May Thu 23, 2013 4:09 pm
 Post subject: Help me make a check list please! :O)
PostPosted: Apr Tue 24, 2012 11:34 pm
or should I say....somewhat of an "order of operations" and I don't mean parentheses first. lol :wink:
Ok...so I basically just want to type up a checklist so that I don't forget to do anything. I know Larry (moses_007) has said that he likes to work on a clean project so he cleans/degreases first, IIRC.
Recapping the chassis next (I know that part is uber important!)
I know there will be varying ideas, but what the heck....any takers for #1? Or, maybe if anyone would like to share their own checklist that would be appreciated!
Cheers!
LOVE & LIGHT!
*MaryAntoinette*
You can take the Girl out of Brooklyn...
 Post subject: Re: Help me make a check list please! :O)
PostPosted: Apr Wed 25, 2012 10:59 pm
The first thing I do is clean everything. I too like to work on clean stuff. Then if it's a record player with an amp, I service the changer while I'm waiting for my caps to be delivered. Then I do an overhaul on the amp. Once the changer and amp are done I clean up the cabinet. That's my usual order of operation.
-Cody
"Music these days-It's just noise"
PostPosted: Apr Thu 26, 2012 12:28 am
When you're inspecting the amplifier to determine which capacitors you will need to order, take that opportunity to measure the resistors. That way you can order any you need at the same time. Inspect any power resistors (large, ceramic) carefully to make sure their leads are secure and won't break if flexed gently. They have a habit of breaking off if you even look at them wrong while replacing capacitors. Then you'd have to make another order.
-David
PostPosted: Apr Thu 26, 2012 2:03 am
That's what I am talking about! Thanks, Guys! Anyone else want to add to my list and side notes? :)
LOVE & LIGHT!
*MaryAntoinette*
PostPosted: Apr Thu 26, 2012 2:36 am
Some people like to take a picture of everything as they go so if they have a problem they can look at the pictures and figure out at which step they messed up. I find that doing this makes everything take twice as long. When i am restoring an amp or radio, I highlight the schematic as I go. Each cap I replace I check to make sure its going to the right place so i have confirmation that everything is correct. By the end the schematic is a bright neon color! :lol:
-Cody
Also, How is the 45 player coming along? Cant wait to see it finished!!
PostPosted: Apr Thu 26, 2012 3:06 am
13crhuber wrote:
-Cody
Lol...Rust is my enemy! I am so mad about all this rust. It is COMPLETELY taken apart and I spend whatever time I have trying to get the rust off! I REEEEEAAALLLY hope I can get her back together again. sigh. Thanks for asking!
I can do it....or should I say....I think I can...I think I can.? Lol. Will keep you posted! :wink:
I have come to the conclusion that buying phonographs locally leads to less rust...Colorado is very dry. Lol
LOVE & LIGHT!
*MaryAntoinette*
PostPosted: Apr Thu 26, 2012 4:12 am
Which areas are rusted? I thought I spotted only one nickel-sized rust spot on top of the motorboard. Were there more?
I would power-sand it off, coat with rust reformer, do a fine sanding, prime and paint.
-David
PostPosted: Apr Thu 26, 2012 3:54 pm
sanding block works well. use course sand paper. garnet is the best. you will be surprised how fast this will take it down to bare metal. prime it with sandable primer. #400 wet/dry sand the primer. paint with matching spray paint of your liking :shock:
CAUTION: Im no expert
PostPosted: Apr Thu 26, 2012 4:00 pm
Thanks for the tips, Guys.
Yes there is a spot on top of the motor board about the size of a nickel....that whole piece will be refinished. The underside had lots of rust spots, and the entire outside edge is covered with rust along with some on the inside edge. Also, half of the removable chassis cover is covered in rust with some inside the chassis which has been difficult to get to.
LOVE & LIGHT!
*MaryAntoinette*
PostPosted: Apr Fri 27, 2012 4:26 am
You may want to get a Dremel tool if you don't already have one. There are a number of sanding and grinding attachments for it that would make this kind of work go much faster.
-David
Post New Topic Post Reply  [ 10 posts ]  Moderator: Larry Hillis
Users browsing this forum: jmsent and 5 guests
