Page 1 of 1
[ 10 posts ] |
| Author |
NumberMaj 1
Post subject: Magnavox changer 520170 same as? Posted: Apr Thu 26, 2012 3:33 pm |
Need to know the actual mfr of Magnavox changer 520170, Garrard, Webster? Thanks. Bill J.
| Top |
Brian McAllister
Post subject: Re: Magnavox changer 520170 same as? Posted: Apr Thu 26, 2012 4:34 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2555 Location: Sarasota FL USA
| Top |
NumberMaj 1
Post subject: Re: Magnavox changer 520170 same as? Posted: Apr Thu 26, 2012 6:17 pm |
That's my problem Brian. The Magnavox console is a Model 52F, chassis CR-176 from 1941 and has a more modern replacement changer. The 520170 changer was used on a number of early Magnavox units. I've been checking some thru google but no luck. Bill J.
| Top |
neali
Post subject: Re: Magnavox changer 520170 same as? Posted: Apr Thu 26, 2012 7:30 pm |
Joined: Mar Thu 31, 2011 4:52 am Posts: 1795 Location: Long Island
| Top |
Ken Doyle
Post subject: Re: Magnavox changer 520170 same as? Posted: Apr Thu 26, 2012 7:51 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1542 Location: Haledon NJ USA
According to Sams the book "Record Changers and Recorders" it should be a Seeburg model B record changer.
Ken D.
| Top |
Ken Doyle
Post subject: Re: Magnavox changer 520170 same as? Posted: Apr Thu 26, 2012 9:36 pm |
| Top |
neali
Post subject: Re: Magnavox changer 520170 same as? Posted: Apr Thu 26, 2012 9:37 pm |
Ken Doyle wrote: Nice! Sounds original.
| Top |
NumberMaj 1
Post subject: Re: Magnavox changer 520170 same as? Posted: Apr Thu 26, 2012 10:51 pm |
Thanks very much Ken. Don't have one so will be looking for a good drop-in replacement. Bill
| Top |
Ken Doyle
Post subject: Re: Magnavox changer 520170 same as? Posted: Apr Thu 26, 2012 11:14 pm |
I have a slightly differnt model Seeburg changer in my Emerson ER-370 and I want to let you know that the tonearm is a bit on the clunky side and will not track at less than about 12 grams. On the bright side, the changer was easy to overhaul and handles a 6 record 12-inch record stack with no problem. The idler wheel has a removable tire that is easily replaced with an o-ring from the hardware store. If you want to play your good records on it, you might want to go the "resto-rod" route.
Ken D.
| Top |
NumberMaj 1
Post subject: Re: Magnavox changer 520170 same as? Posted: Apr Sat 28, 2012 12:48 am |
I've been looking for an excuse to use one of my Collaro models with the "finger" but been waiting on the right Magnavox. This 52F I thought about using for 78's only. But I have been thinking of ways to go stereo with it. But then again where to put it as I'm downsizing from the last downsizing. Bill J.
| Top |
Users browsing this forum: No registered users and 2 guests |
