Page 1 of 1
[ 9 posts ] |
| Author |
George Flanagan
Post subject: Record Player Problem Posted: May Thu 03, 2012 2:34 am |
Hello, i have an admiral portable turntable. the sound is fine and the player is fine, but the speed is slower than normal. please tell me if anybody knows how to correct this. thank you.
| Top |
RepairTech
Post subject: Re: Record Player Problem Posted: May Thu 03, 2012 4:56 am |
| Member |
Joined: Jan Sun 24, 2010 7:59 am Posts: 6171 Location: Pro Tech, Philadelphia Pa.
Most likely the rubber parts are dryrotted/shot, and the whole changer needs overhauling - including working on the amp, because it's not safe to use after 50+ years. Restoration time.
_________________ "Accept the fact that some days you are the pigeon, and some days you are the statue."
| Top |
tubeAMP
Post subject: Re: Record Player Problem Posted: May Thu 03, 2012 3:42 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2753 Location: Gainesville, Florida
lubrication helps.. quick-n-easy use aerosol lube like white lithium. if that fixes it then you know what the problem is
_________________ CAUTION: Im no expert
| Top |
RepairTech
Post subject: Re: Record Player Problem Posted: May Thu 03, 2012 4:18 pm |
| Member |
tubeAMP wrote: lubrication helps.. quick-n-easy use aerosol lube like white lithium. if that fixes it then you know what the problem is  I'd never recommend a spray lubricant on record changers - too much chance for overspray onto parts that shouldn't be lubed. Tsk tsk...
| Top |
tubeAMP
Post subject: Re: Record Player Problem Posted: May Thu 03, 2012 8:55 pm |
ya jus gotta bee careful
| Top |
dberman51
Post subject: Re: Record Player Problem Posted: May Thu 03, 2012 10:41 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2307 Location: Boston, MA USA
Most of us like to lubricate turntables extremely sparingly -- much less lubricant than you could ever apply from a spray can. The spray grease is great for the car though, hood latch, door hinges, etc. That's what it was made for.
-David
| Top |
RepairTech
Post subject: Re: Record Player Problem Posted: May Fri 04, 2012 12:37 am |
| Member |
dberman51 wrote: Most of us like to lubricate turntables extremely sparingly -- much less lubricant than you could ever apply from a spray can. The spray grease is great for the car though, hood latch, door hinges, etc. That's what it was made for.
-David Indeed, David - ya use the proper tools for the job, or don't do the job at all.
| Top |
noisebox
Post subject: Re: Record Player Problem Posted: May Fri 04, 2012 3:50 am |
Joined: Mar Mon 02, 2009 11:48 pm Posts: 2875 Location: 97381, USA
| Top |
George Flanagan
Post subject: Re: Record Player Problem Posted: May Fri 04, 2012 11:59 pm |
ok, i have lubricated the parts with a small amount, however, it still plays slow, but not too slow. i do not think my turntable could be restored by myself, i have no idea on the matter  . thank you all again for the help. p.s . my player is from the 60's, so it's not too old.
| Top |
Users browsing this forum: No registered users and 4 guests |
