| Author |
scrivener
Post subject: How many turntable rotations after RCA RP-190 shut-off? Posted: May Wed 16, 2012 4:14 pm |
Joined: Jun Fri 05, 2009 4:20 pm Posts: 135 Location: Eastern PA
On my RCA Victor EY 7 circa 1955-57, I notice that the turntable rotates a couple of times after shut-off (with a full stack of 14 records), while on my older EY-3 circa 1950-52, the turntable stops after only about a quarter- or half-revolution. Is this just a difference between models or an indication that the spindle bearings need to be re-greased? Otherwise, performance is comparable in these units. BTW, the EY-3 has the Willie Bosco O-ring idler (which works great and fixed a slight flutter) while the other unit has a traditional idler (and a slight flutter...) Also, I was using white lithium grease on sliding metal parts and noticed that it turned yellow and got viscous, apparently due to heat build-up. So now I'm trying a red high-temp wheel bearing grease that resembles the old "Stay-Put." Any suggestions there?
| Top |
RepairTech
Post subject: Re: How many turntable rotations after RCA RP-190 shut-off? Posted: May Wed 16, 2012 4:22 pm |
| Member |
Joined: Jan Sun 24, 2010 7:59 am Posts: 6171 Location: Pro Tech, Philadelphia Pa.
The platter inertia at shutoff is determined basically by the motor itself. Another factor can be the grip of the idler wheel.
....it all depends on how WELL the changer has been serviced.
_________________ "Accept the fact that some days you are the pigeon, and some days you are the statue."
| Top |
ggregg
Post subject: Re: How many turntable rotations after RCA RP-190 shut-off? Posted: May Wed 16, 2012 4:31 pm |
Joined: Aug Sun 01, 2010 1:12 am Posts: 5218 Location: Minnesota
Some Garrards actually have a brake that stops it immediately after shut off. You can tell by the little ping they make at the end.
| Top |
RepairTech
Post subject: Re: How many turntable rotations after RCA RP-190 shut-off? Posted: May Thu 17, 2012 1:19 am |
| Member |
ggregg wrote: Some Garrards actually have a brake that stops it immediately after shut off. You can tell by the little ping they make at the end. I've never seen a "brake" on a Garrard..... tell me which model, perhaps I never saw it yet. And I've pretty much serviced them all.
| Top |
Ken Doyle
Post subject: Re: How many turntable rotations after RCA RP-190 shut-off? Posted: May Thu 17, 2012 2:13 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1542 Location: Haledon NJ USA
RepairTech wrote: I've never seen a "brake" on a Garrard..... tell me which model, perhaps I never saw it yet. And I've pretty much serviced them all. The RC121 is one: http://www.youtube.com/watch?v=UCBUCPZPXn0"DING" Time to turn the records over. Ken D.
| Top |
ggregg
Post subject: Re: How many turntable rotations after RCA RP-190 shut-off? Posted: May Thu 17, 2012 2:32 am |
That's the one I have and that's what it does. Maybe it's not meant as a brake, what Ken said, a sound to tell you it's finished. It stops the platter quick though.
| Top |
MaryAntoinette
Post subject: Re: How many turntable rotations after RCA RP-190 shut-off? Posted: May Thu 17, 2012 3:00 am |
| Member |
Joined: Mar Mon 19, 2012 8:20 pm Posts: 254 Location: Denver, Colorado
Boy, oh boy, RepairTech...you are superbly knowledgable....but, boy are you snarky!
_________________ LOVE & LIGHT! *MaryAntoinette*
You can take the Girl out of Brooklyn...
| Top |
RepairTech
Post subject: Re: How many turntable rotations after RCA RP-190 shut-off? Posted: May Thu 17, 2012 3:23 am |
| Member |
Ken Doyle wrote: RepairTech wrote: I've never seen a "brake" on a Garrard..... tell me which model, perhaps I never saw it yet. And I've pretty much serviced them all. The RC121 is one: http://www.youtube.com/watch?v=UCBUCPZPXn0"DING" Time to turn the records over. Ken D. Ahh, the RC121! That's one I've never worked on. The usual Garrard changers that come into my shop are a bit more "modern" - Lab series on up to the infamous Z-100 era. That ding is annoying.
| Top |
RepairTech
Post subject: Re: How many turntable rotations after RCA RP-190 shut-off? Posted: May Thu 17, 2012 3:26 am |
| Member |
MaryAntoinette wrote: Boy, oh boy, RepairTech...you are superbly knowledgable....but, boy are you snarky!  Superbly Knowledgeable, yes, yes I am. But please, spell it correctly.
| Top |
MaryAntoinette
Post subject: Re: How many turntable rotations after RCA RP-190 shut-off? Posted: May Thu 17, 2012 3:32 am |
| Member |
RepairTech wrote: MaryAntoinette wrote: Boy, oh boy, RepairTech...you are superbly knowledgable....but, boy are you snarky!  Superbly Knowledgeable, yes, yes I am. But please, spell it correctly. Lol...I do know how to spell...typing on this nook is horrid...but, seriously...I do learn a lot from you & get a kick out of your sarcasm. Are you like this in real life or only on the forum?
| Top |
dberman51
Post subject: Re: How many turntable rotations after RCA RP-190 shut-off? Posted: May Thu 17, 2012 3:56 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2308 Location: Boston, MA USA
RepairTech wrote: That ding is annoying. That would be disconnected in about five seconds if I had one of those changers. -David
| Top |
RepairTech
Post subject: Re: How many turntable rotations after RCA RP-190 shut-off? Posted: May Thu 17, 2012 4:02 am |
| Member |
dberman51 wrote: RepairTech wrote: That ding is annoying. That would be disconnected in about five seconds if I had one of those changers. -David Anytime I've encountered one of those old "RC" critters, it gets tossed and replaced by something more refined. They always have hardened, broken platter mats. And I think they're ugly as sin. - the arm reminds me of a turd in a toilet. I might have a few laying in a "parts" pile in the corner of the shop.
| Top |
Larry Hillis
Post subject: Re: How many turntable rotations after RCA RP-190 shut-off? Posted: May Thu 17, 2012 8:33 am |
| Moderator |
Joined: Apr Wed 09, 2008 3:37 am Posts: 9665 Location: Little Rock, Arkansas
Your EY-7 has a rare condition known as spinitis.  Don't let it bother you... just spin the 45s and watch the turntable turn.
| Top |
Doug VanCleave
Post subject: Re: How many turntable rotations after RCA RP-190 shut-off? Posted: May Thu 17, 2012 11:29 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 3523 Location: Berkley, Michigan
ggregg wrote: Some Garrards actually have a brake that stops it immediately after shut off. You can tell by the little ping they make at the end. That hammer on a school bell sound would be much less noticeable if the felt brake shoe was replaced. In other words his Garrard needs a brake job.
_________________ That warm tube sound can usually be overcome by turning up the treble.
| Top |
walyfd
Post subject: Re: How many turntable rotations after RCA RP-190 shut-off? Posted: May Thu 17, 2012 4:02 pm |
I have an OLD (1920 or so) Edison wind up Diamond Disc unit that has a little cork on a pawl that stops the table.
"SNARKY"--I like that. That just might stick.
| Top |
Brian McAllister
Post subject: Re: How many turntable rotations after RCA RP-190 shut-off? Posted: May Thu 17, 2012 4:43 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2555 Location: Sarasota FL USA
| Top |
electra225
Post subject: Re: How many turntable rotations after RCA RP-190 shut-off? Posted: May Fri 18, 2012 5:19 am |
Joined: Dec Sat 23, 2006 5:49 pm Posts: 837 Location: san tan valley, az
I have no idea what a "nook" is, but, Mr.Repair Tech, sir, Mary spelled it correctly, while, unfortunately, YOU spelled it incorrectly. There is no "e" after the "g". "K-N-O-W-L-E-D-G-A-B-L-E". Knowledgable. I just looked it up to be certain. Sorry.....................GREG
_________________ Always be yourself. Everybody else is already taken.
| Top |
Larry Hillis
Post subject: Re: How many turntable rotations after RCA RP-190 shut-off? Posted: May Fri 18, 2012 5:26 am |
| Moderator |
electra225 wrote: I have no idea what a "nook" is, but, Mr.Repair Tech, sir, Mary spelled it correctly, while, unfortunately, YOU spelled it incorrectly. There is no "e" after the "g". "K-N-O-W-L-E-D-G-A-B-L-E". Knowledgable. I just looked it up to be certain. Sorry.....................GREG LMAO!
| Top |
bastardbus
Post subject: Re: How many turntable rotations after RCA RP-190 shut-off? Posted: May Fri 18, 2012 6:09 am |
Joined: Jan Mon 25, 2010 7:51 am Posts: 1282 Location: Toledo, Ohio
| Top |
RepairTech
Post subject: Re: How many turntable rotations after RCA RP-190 shut-off? Posted: May Fri 18, 2012 6:36 am |
| Member |
According to my Webster's Dictionary, it's knowledgeable... A way to remember this is "If you're knowledgeable, your 'knowledge' will be 'able' to wow your friends!"
Hope this helps! Source(s): Webster's Dictionary
| Top |
Who is online |
Users browsing this forum: No registered users and 3 guests |
