It is currently Oct Sat 20, 2018 1:20 am
 Post subject: help with another schematic
PostPosted: Jan Wed 15, 2014 5:23 pm
Need a schematic for the amp
Magnavox Model 1SP263F Record Player / Tube Amp Console, and Model S041 Extension Speaker with record storage.
looks just like these.
Thanks in advance.
-Mark
-Mark
Hear this all the time ,"its just needs a belt thingy and a new needle" lol
 Post subject: Re: help with another schematic
PostPosted: Jan Thu 16, 2014 11:34 pm
Mark,
When you deal with Magnavox the Models don't help too much unless some body has same and/or there's published info on the web. You need to get chassis numbers for the most part. I'm almost 100% sure SAMS 458-12 will cover your set. Let me know. When you do get inside would you please post the AMP number. More info means next person may hit upon it in a search.
Bill J.
Here's link to the SAMS.
https://app.box.com/s/87rlvqtizmauyr3qcgeo
PostPosted: Jan Fri 17, 2014 8:52 pm
Bill I will open this up this weekend and post the number your always a big help with the schematics. Your the best Bill High Five.
-Mark
The Vintedge CO
-Mark
PostPosted: Jan Sat 18, 2014 3:58 pm
More than likely I have the factory manual for it in my Magnavox Manuals. As the
man said "I just need the chassis number". I'll be out of pocket not able to check
until at least Tuesday the 21st. I'll be happy to scan it and email you a copy.
However beautiful the strategy, you should occasionally look at the results.
Winston Churchill
PostPosted: Nov Fri 10, 2017 9:46 am
I'm a total newbie to the world of console repair (guitar repairman by trade) and I'm afraid I don't have the terminology to explain my issue with my console. This schematic provided in this thread is the only clue I have to show for hours of searching the internet for something referencing the console in question. I'm wondering if one of you fine people might have a similar schematic outlining the mechanical components of the changer or possibly an owners manual or really any information relating to the console in the aforementioned schematic. I'll provide the information I have in hopes it might help! Thanks so much for taking the time to help and sorry for the vagueness!
Console is an late 50's/early 60's Magnavox
model number 1SP263 F (appears exactly as pictured in the electronics schematic)
Carved in to the back stretcher is the number 524-38-4937D
The piece I need to replace is a plastic fitting with a metal bushing that seems to signal the turntable motor to start.
PostPosted: Nov Sat 11, 2017 6:42 pm
To be sure about your needs what are the numbers from the underside of the record changer. Also, it's possible to find number under the mat. Once the part is identified from the documentation perhaps one can be obtained from a junked changer.
Bill J.
