It is currently Oct Mon 15, 2018 8:45 pm
Post New Topic Post Reply  [ 73 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: Rebuilding Crystal Cartridge
PostPosted: Oct Sun 02, 2016 6:56 pm
Also, what do you guys think about using the kccc cartridge replacement kit from voice of music?
PostPosted: Oct Sun 02, 2016 8:11 pm
Way too much output for this application. The GE cart puts out only about 1/10 of a volt, the kit puts out 1.3 volts. For the most part, you can't replace a magnetic cartridge with a ceramic cartridge.
PostPosted: Oct Sun 02, 2016 8:25 pm
Sorry Ken. I am working on a Zenith 5R086 at the same time, which does have a crystal cartridge. I am having difficulty finding a donor Crystal cartridge that I can scavenge the Crystal from in order to rebuild the Zenith cartridge. I purchased some very inexpensive ceramic cartridges, and thought I might give them a try. I attached a photo of the ceramic element. Failing that, I was wondering about using the kccc kit from voice of music, and just wanted a general opinion on what you guys thought about that kid
PostPosted: Oct Sun 02, 2016 8:47 pm
I believe that kit should work just fine on the Zenith as long as you can get the tracking force down a bit without effecting the operation of the end-of-record trip mechanism.
PostPosted: Oct Sun 16, 2016 3:06 am
Anybody ever tried this setup?
PostPosted: Oct Tue 18, 2016 1:01 am
Seems like too simple of a solution but I'm not knocking the idea at all. It's a great idea and definitely worth a try. Maybe cement it in place with a few tiny dabs of silicon rubber that could be easily removed if it doesn't work.
What is this kit? I can't find it anywhere on the voice of music web page. Can someone post a link?
PostPosted: Oct Tue 18, 2016 1:27 am
http://www.ebay.com/itm/Turntable-Phono ... SwQjZXP-eo
PostPosted: Oct Tue 18, 2016 5:59 am
http://www.thevoiceofmusic.com/catalog/ ... s=78%20rpm
PostPosted: Oct Fri 21, 2016 5:20 pm
Oh, thanks. Now I can find it and in fact, I had purchased one of these a few years ago but not from VM. I don't recall where but also had an idler rebuilt from the same guy. A very nice older gentlemen.
On my Zenith 7S681 I could only get the weight down to about 8grams (the max). Still a bit too heavy I think but works well.
https://www.youtube.com/watch?v=YF_i11bg7lM
PostPosted: Oct Sat 22, 2016 5:22 am
Very, very cool!
PostPosted: Oct Sat 22, 2016 11:47 pm
The results of putting a $1.79 dual ceramic cartridge internals into the Astatic L26 cartridge were surprisingly good. The tone is almost as good as a new pfanstiehl P 51-3. The volume is decent. Not as good as the P51-3, but a very inexpensive fix, which keeps the player visibly accurate.
Jeff
PostPosted: Oct Sun 23, 2016 12:48 pm
Wow that's great! How did you end up bonding the various parts together? Especially where the stylus holder meets the crystal?
PostPosted: Oct Sun 23, 2016 3:08 pm
I put a tiny drop of gorilla glue on the rubber piece holding the very end of the ceramic rods. I also put a very tiny dab of silicone RTV on the rubber piece closest to the terminals. I have a feeling that a more rigid connection to the stylus holder would probably increase the volume. I also suspect that this setup will only work with an amplified system. I am working on a GE model 12 now. I will experiment with it as well.
Jeff
PostPosted: Oct Sun 23, 2016 3:30 pm
Do you mean inserting a preamp ahead of the power amp?
PostPosted: Oct Sun 23, 2016 9:01 pm
That is my impression, based upon the comments of some more seasoned gentlemen in this forum. Somewhere, I saw a schematic for a very basic preamp, which only involved a couple components. I wish I could still find that schematic.
Jeff
PostPosted: Oct Mon 24, 2016 5:29 am
Hi Jeff,
A more rigid connection to the "stylus holder" will indeed increase output, to the expense of
exaggerated record surface noise. A softer bond would filter the high frequency noise and also
protect the ceramic element from breakage should one bump accidently the stylus, say on the side
of the record or drop the tonearm.
Some stylus replacement for early Astatic such as the L-71, L-26, etc. were molded in nylon to increase compliance
and lower noise.They were quite effective in that area.
Syl
Jeff
PostPosted: Oct Mon 24, 2016 5:42 am
Syl,
Thanks for the info. I would like to try replacing the stylus as well. Can you make a recommendation.
Jeff
PostPosted: Oct Mon 24, 2016 2:03 pm
Using the Pfanstiehl 911 type cartridge which is part of the KCC-C kit discussed earlier, I found it had adequate sound output for my Zenith which probably had a 3V cartridge originally. The output of the 911 is rated about 1.3 volts and I do have to say the volume is noticeably lower than the radio. But I do find the radio to be a little too loud and keep the volume very close to the CCW position when listening to it. When playing records, I do have to turn the volume up more but I find there is plenty of volume available.
I don't know much about these stylus but I know there are two types. One being straight and the other bent like a S shape. I've read in places that you can use either one but then I ran across a web page somewhere that said you shouldn't interchange them. I don't recall the reason for this. So its probably best to stick with the type that was in there assuming it wasn't switched out. Check eBay, I purchased a couple NOS a while back. Your question was intended for Syl. Maybe he knows better.
This post here shows a couple simple preamp circuits. Unfortunately you need a log in to see them but there is an interesting discussion on this topic. I thought I had a login but cannot seem to find my credentials.
http://audiokarma.org/forums/index.php?threads/question-on-ceramic-cartridge-output.529564/
PostPosted: Feb Tue 21, 2017 10:28 pm
Are these the "guts" from one of those cheap $2 Chinese cartridges on eBay?
.....Richard.....
PostPosted: Feb Wed 22, 2017 6:40 am
Yes Richard. The red and black ones. I hope you have a steady hand and gentle touch, as the ceramic rods are pretty fragile. I ordered several to start.
Jeff
Post New Topic Post Reply  [ 73 posts ]  Moderator: Alan Voorhees Go to page Previous  1, 2, 3, 4  Next
