It is currently Jul Tue 17, 2018 6:28 am
 Post subject: AMI F 120 Jukebox stopped returning records!
PostPosted: Nov Fri 24, 2017 5:17 pm
It retrieves a record and put it down with no issue. However when the record is done it will not put it back. Any ideas here?
I have a video of this here, https://youtu.be/-b4E8t9Clbc
Anyhelp would be greatly appreciated!!
 Post subject: Re: AMI F 120 Jukebox stopped returning records!
PostPosted: Nov Fri 24, 2017 11:35 pm
I don't have an electrical print for this jukebox before me, nor am I knowledgeable at all on jukeboxes (as I mentioned previously). With that being said, and given the successive problems that you are experiencing with this jukebox, I don't think that it would hurt by giving all of those contacts on that cam a complete ohmic check. Clean any contact which doesn't pass muster. Just be sure that the power is removed before checking/cleaning any of those contacts.
I suppose that you could also disconnect the power at the time that the gripper fails to return the record to the slot, and check each of those contacts (and/or observe anything else that obviously seems to be out of whack) which are closed.
I could very well be shooting in the dark here as I don't really know what that tone arm is actually tripping as it skates past the last groove.
PostPosted: Nov Tue 28, 2017 4:20 am
Can you cancel the record from the switch on the back of the machine? If so, the trip switch in the bottom of the mech is out of adjustment. If not, all the contacts on both sides of the cam need to be checked for proper setup. See attached drawing. Many symptoms with this changer can be cured this way. Some of the other problems you have posted in other threads can be related to these switches.
PostPosted: Dec Sun 17, 2017 6:53 pm
Thank you for your responses. This is helping a ton!
Mrlee,
"Can you cancel the record from the switch on the back of the machine?" No, when I press the red button nothing happens. When you say contacts on both side of the cam are you talking about the contacts on the the switches below the cam? I have cleaned these with no change.
PostPosted: Dec Sat 23, 2017 2:27 pm
Clean and adjust the contacts on the reversing relay. Upper left relay in your video.
I've done many of these machines over the years. If this doesn't work, you will need
to use a meter or test light and trace where the circuit is open in this part of the cycle.
Kurt arcade-antiques
PostPosted: Dec Thu 28, 2017 4:46 am
Then it would seem that you are not getting power to the transfer motor.
Yes those are the switches. Are they adjusted as shown in the picture? The contact at CS2 in the picture is part of the power supply to the motor. Plus a contact in the reversing relay.
