It is currently May Fri 25, 2018 1:24 pm
 Post subject: Cobramatic question
PostPosted: Nov Thu 30, 2017 1:21 am
Hi all, got a question regarding the phono function.When its on phono should i hear station noise (without the phono actually playing? I restored this unit a long time ago and fired it up the other day.I'm not hearing stations just off station noise.The function switch is excellent.Thanks for any info.
 Post subject: Re: Cobramatic question
PostPosted: Nov Thu 30, 2017 4:48 am
I'm not sure what you are asking. You shouldn't hear radio stations when the switch is set to phono.
Are you talking about "hiss" sound that is similar to between radio station noise? You might hear that when no record is playing.
Tim
PostPosted: Nov Thu 30, 2017 5:18 am
You might have to touch up the tuning of the Cobramatic oscillator.
-David
PostPosted: Nov Thu 30, 2017 12:08 pm
Yes, I'm talking about the hiss off- station noise when it's switched to phono. Don't remember hearing that ,but maybe it is normal?
PostPosted: Nov Thu 30, 2017 6:08 pm
There should be little noise on the phono mode. The radionics pick up depends a lot on a good connection between the pins on the cartridge and the input to the oscillator. Make sure the contacts are clean and solid! Then, be sure the oscillator is peaked to its optimum. There may be other components that can cause hiss, such as leaky capacitors, or weak resistors, or even a noisy vacuum tube, especially the ones in the oscillator discriminator circuit.
PostPosted: Nov Thu 30, 2017 6:47 pm
Yes, the oscillator is peaked. All the old caps were replaced. I'll check he resistors in the circuit. I did check the tubes in the oscillator circuit. thanks....
PostPosted: Dec Fri 01, 2017 7:27 am
I had static in one Cobra-matic that turned out to be a bad phono plug. I replaced the entire phono cable with a new one, and the player is now quiet as a mouse when no records are playing.
PostPosted: Dec Fri 01, 2017 12:07 pm
Larry, was just thinking of that! I'll replace it and see. Thanks
PostPosted: Dec Sun 03, 2017 5:49 pm
Replaced the phono cable,no change
PostPosted: Dec Sun 03, 2017 11:52 pm
Like startgroove said, noise can come from capacitors, resistors or tubes. Unfortunately the noise isn't detected on most tester. (Some tube testers do have a place to plug in earphones.) The noise you are talking about (hiss) is like a quiet 'bacon sizzle' isn't it? That's a random type of signal. You might try substituting tubes, or replacing resistors. Another possibility is that you just don't remember how noisy it was the last time you played it, it may never of been as quiet as modern players.
Tim
Post New Topic Post Reply  [ 10 posts ]  Moderator: Alan Voorhees
