It is currently Jul Fri 20, 2018 9:39 am
 Post subject: Zenith (VM) Changer 12" record button Scraping
PostPosted: Dec Wed 06, 2017 2:25 am
I'm sure this has been discussed before but I couldn't find anything because I'm likely using the wrong terms. Just finished cleaning up a late 60's VM changer, installed a "new" idler wheel and everything works except the 12" record detector button is scraping on each turn when a record is on the table. No scraping when rotating without a record. Its a fairly noticeable scraping sound. Is that normal and is there something I can adjust to reduce?
Thanks all!
 Post subject: Re: Zenith (VM) Changer 12" record button Scraping
PostPosted: Dec Wed 06, 2017 2:48 am
I think you mean the 10" sensor button.
The only times I have experienced this is when one or both of the center bearing washers are missing causing the turntable platter to ride too low.
PostPosted: Dec Wed 06, 2017 3:16 am
The bearing stackup is good. I think the long "spring" under the platter was a little warped. When It was pushed down, the spring was at an angle to the platter. I worked it a little so that it is parallel to the platter when pushed. All good with the scraping now. And right with the 10" sensor. I do minor repairs and restorations and have working on a few vintage changers over the past couple of years. This is the first VM that I completely stripped down and reassembled.
Problem I have now is that the changer is not sequencing properly. Record drops but arm never moves over and plays. Changer goes into an immediate reject. Only immediate issue I see is that the pin that the 10" sensor should hit never rises up high enough during a cycle to be pushed down. I'm guessing I have something slightly off on the reassembly. Works fine in manual but won't start in automatic. Any ideas?
PostPosted: Dec Wed 06, 2017 5:59 am
if the trip link assembly isn't positioned just right when you reassemble the cycling mechanism, it won't engage the trip lever on the cam wheel. Sometimes it takes a couple of tries to line it up correctly as it may slip out of position when re-installing the cycling mechanism.
Here's is a step-by-step thread that may help:
http://www.antiqueradios.com/forums/viewtopic.php?f=9&t=186294
Ed
PostPosted: Dec Wed 06, 2017 9:00 pm
Thanks and I'll give that a try tonight. Also ordered the service manual last night which should help!
PostPosted: Dec Sat 09, 2017 3:36 pm
Thanks for the help folks, after 5 or 6 more disassembly and re-assemblies I have the table working pretty well. One last question, and this may be a stupid one. The changer works great with more than one record, but if I go to play just one record it won't bring the tonearm over to the beginning of the record, it just cycles off. Is that what it is supposed to do?
Thanks.
PostPosted: Dec Sat 09, 2017 3:43 pm
Are you letting the record drop? If you put the record on the platter and the record arm over the spindle, it will shut off. If you are placing a single record on the platter, leave the record support arm to the side and it should work. After the record starts playing, swing the arm to the spindle, and the player will shut off when the record is over.
Alternately, place the record on the spindle held by the support arm, turn the knob to reject, the record should drop and start playing.
Also when playing a single record manually that is already on the platter, don't turn the knob to reject, or it will cycle off. Turn the knob to on, and manually lift the tone arm to the lead in groove of the record. In that case, I think the support arm can be over the spindle.
Ed
PostPosted: Dec Sat 09, 2017 4:49 pm
Ed,
It works fine in manual. Problem is single record on spindle, support arm over spindle, knob to reject. The record drops, the changer cycles but the arm lifts up and then remains on tonearm rest. Works fine with two records.
PostPosted: Dec Sat 09, 2017 5:07 pm
It's been a while since I worked on one of these, but my brain isn't firing on all cylinders this morning; I just can't think of the fix at the moment. It may be an adjustment in the support arm linkage, but not sure. Have you tried the search function at the top of the page? I think there is at least one thread on this specific issue.
Ed
PostPosted: Dec Sat 09, 2017 9:55 pm
I can tell that the locater arm is not resetting correctly and not allowing the 7" arm to poke up through the chassis. I had it working correctly for a bit and it cycled correctly but now the locater arm is staying in the way again. I'll search on that problem and see if I can find something.
PostPosted: Dec Sun 10, 2017 2:35 am
Generally, once the mechanism is cleaned and lubricated, and correctly re-assembled, it works reliably. However, every now and then you get a mechanism where someone tried to force things, resulting in something getting bent. Examine components carefully and look for a bent lever or linkage. It does happen, and can cause erratic cycling.
Ed
PostPosted: Dec Sun 10, 2017 4:54 am
A common reason for the changer to shut-off after
last record drops is that the record support arm is bent.
Usually the arm is bent up, because people grab the
arm from the front when they lift it to place or remove
records on the record spindle.
Here's a problem list from a V-M 1200 series changer service file:
Let us know what model your V-M is.
Hotwax
PostPosted: Dec Sun 10, 2017 1:40 pm
Its a 1287 Changer. I have the service manual. Don't thinks the support arm, I've looked at it pretty closely. Its not really that the last record fails to play, its that a single record fails to play. If I stack two or more it plays them all, but if I only load one on the spindle it won't play. It seems to be related to the 7" tab not being able to come up through the platter because the mechanism doesn't fully reset.
PostPosted: Dec Mon 11, 2017 2:33 am
RE: changer shutting off with one record on spindle:
Does this happen if you also engage the 12 inch index
lever with your finger at the same time the single
record loaded on spindle drops ?
Hotwax
PostPosted: Dec Mon 11, 2017 3:23 am
I tried with a my finger on the 12" sensor and it still does not work. If I hold the support arm slightly up it works. I noticed when 2 records are on the spindle, the support arm doesn't seem to immediately go all the way down after the last record drops. It moves all the way down after the arm has moved over the record. Very odd. I'm about to give up as I've spent way to much time on this one!
PostPosted: Dec Mon 11, 2017 6:48 am
I understand the frustration re: shut off problem.
Here's what I did with same problem > or < with a 1200 model V-M.
I found an old email exchange. Maybe these ideas will help.
1. Gary at V-M stated re: errant shut off problem:
"This is usually a sticky escape lever on slide.
Remove spring and flood lever with rubbing alcohol.
Use strips white paper and CAREFULLY coax all the old,
sticky lube from under both sides of riveted lever.
Repeat until paper comes out clean.
Don’t force it or you will have paper underneath the lever jamming it too.
Go back 10 min later after alcohol has dried,
and if lever moves free, reinstall spring.
Do not lubricate escape lever, this part should be dry."
2. What I found needed attention after doing what
Gary suggested and problem persisted:
"Well, I knew that escape lever was squeaky clean after rebuild.
So, after partial disassemble, I found that the gear assembly was
binding on the reset lever just enough to create the problem.
Then the trip finger cam wasn't engaging the trip link, so I bent the
90 degree tab on the trip link so it would engage."
Hotwax
Post New Topic Post Reply  [ 16 posts ]  Moderator: Alan Voorhees
