| Author |
35Z5
Post subject: 12AV6-12CS6 Transmitter(Revised Schematic) Posted: Mar Mon 29, 2010 2:40 am |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 8651 Location: Chesapeake VA
Finally a transmitter utilizing a single, cheap surplus transformer... Norm found xfomers at EGM with 24V & 36v windings that work great and I've been designing around it and the cheap(did I mention cheap?) 12CS6, many vendors have these for a $1 each... Also uses the common 12AV6 or 12AT6 almost everyone should have one of these laying around... Bill Hamre is in the process of stocking a parts kit that will include the xformer and 12CS6... http://amradio.freeiz.com/12av612cs6rev2.jpgR/S PCB is cut in half and holes drilled to route wires from underside to one side, where the bundle(five wires) is tied together... This allows top cover to be raised at 90* angle without stressing wiring... http://amradio.freeiz.com/transmitter/12cs6txb.jpgChassis wiring, again as in 24v Tx, utilizes one of Bob Weaver's Earth Potential Facilitators, for grounding... http://amradio.freeiz.com/transmitter/12cs6txc.jpghttp://amradio.freeiz.com/transmitter/12cs6txd.jpg Revised schematic added, please destroy orig dated 04-01-10 and Rev dated 4-10-10... Tom
| Top |
Norm Leal
Post subject: Posted: Mar Mon 29, 2010 2:59 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 28947 Location: Livermore, CA
Looks great, noticed that release date 4-01-10.
Bill - I have plenty of these transformers and EGM has thousands. Shouldn't have a problem with running out. I can send you groups of 12, Priority Mail, when needed. They can also be bought direct from EGM.
_________________ Norm
| Top |
35Z5
Post subject: Posted: Mar Mon 29, 2010 3:07 am |
| Member |
Norm Leal wrote: Looks great, noticed that release date 4-01-10.
Sneak preview...
BTW Radio Shack parts are either up grade(VR-1) or components not included in Bill's kit...
| Top |
hcheetham
Post subject: Posted: Mar Mon 29, 2010 2:24 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 892 Location: Sodus,NY USA
anyway to make the schematic in a downloadable word or pdf file?hard to print or copy from forum page.
thanks
Harold
_________________ Visit us on the web at: sunshineradiomuseum.org W2HJC
| Top |
Brian McAllister
Post subject: Posted: Mar Mon 29, 2010 3:13 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2555 Location: Sarasota FL USA
hcheetham wrote: anyway to make the schematic in a downloadable word or pdf file?hard to print or copy from forum page. thanks Harold
Right click on the image. When the dialogue box opens, click on "view image". The image will open by itself in a new page. Either print or save that image.
_________________ Brian McAllister Sarasota FL http://oldtech.net
| Top |
Mike Yancey
Post subject: Re: 12AV6-12CS6 Transmitter Posted: Mar Mon 29, 2010 3:15 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1024 Location: Dallas, Texas USA
35Z5 wrote: Finally a transmitter utilizing a cheap, single surplus transformer... Norm found xfomers at EGM with 24V & 36v windings that work great and I've been designing around it and the cheap(did I mention cheap?) 12CS6, many vendors have these for a $1 each... ...(snip).
And the hits just keep coming!
Fantastic how we *cough* I mean YOU keep churning out great alternatives. Eh, I'm just a fabricator here; I gaze in wonderment at the designs.
I've built a really nice desktop headphone amp with these 12-volt car radio tubes and they do work very well and are readily available (and for the most part, cheap).
I built this one:
http://www.diyforums.org/MAX/MAXoverview.php
It's off my desk now for a tune-up after about 2-years of nearly daily use. It doesn't use high plate voltages so it uses a 24-volt AC Wall-wart.
Keep 'em coming. Maybe we need to put the 'reference' designs in a spot in the 'resources' area of ARF. There's the 6888, the 2-tube 6888, the 6LE8, the two-tube 6GY6... now 12-V tubes.
Mike Y
Dallas, Texas
| Top |
Naddy69
Post subject: Posted: Mar Tue 30, 2010 1:41 am |
What's the difference between the 12CS6 and 12BE6? I see them listed as one being a sub for the other.
| Top |
Norm Leal
Post subject: Posted: Mar Tue 30, 2010 2:23 am |
Hi
Transconductance from grid #3 is specified on a 12CS6. A 12BE6 is an older tube which doesn't have transconductance from grid #3 controlled as well.
We use grid #3 as audio input so nice to know what to expect. Tom has done experimenting with different tubes. 12BE6 works but doesn't modulate as well. He will probably give details.
| Top |
35Z5
Post subject: Posted: Mar Tue 30, 2010 3:25 am |
| Member |
The 12BE6 has a remote cutoff G3 and will distort with higher levels of audio input, same is basically true of virtually all pentagrid tubes used as mixer-osc in BCB radios... Most charts list 12BE6 & 12CS6 as subs, in reality neither likely perform for the other as intended...
| Top |
Naddy69
Post subject: Posted: Mar Tue 30, 2010 4:05 am |
Quote: in reality neither likely perform for the other as intended...
That's about what I was thinking, since 12CS6 is listed as a Dual Control Heptode. I was surprised to see them listed as subs for each other.
| Top |
BobWeaver
Post subject: Posted: Mar Tue 30, 2010 6:53 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1392 Location: Saskatoon
Tom, How does this transmitter compare to the 6LE8 & 6GY6 transmitters for output power, sound quality etc.?
| Top |
Hemingray
Post subject: Re: 12AV6-12CS6 Transmitter Posted: Mar Tue 30, 2010 12:23 pm |
Joined: Nov Tue 25, 2008 12:47 am Posts: 381 Location: Evening Shade, AR USA
Mike Yancey wrote: And the hits just keep coming! Fantastic how we *cough* I mean YOU keep churning out great alternatives. Eh, I'm just a fabricator here; I gaze in wonderment at the designs. I've built a really nice desktop headphone amp with these 12-volt car radio tubes and they do work very well and are readily available (and for the most part, cheap). I built this one: http://www.diyforums.org/MAX/MAXoverview.phpIt's off my desk now for a tune-up after about 2-years of nearly daily use. It doesn't use high plate voltages so it uses a 24-volt AC Wall-wart. Keep 'em coming. Maybe we need to put the 'reference' designs in a spot in the 'resources' area of ARF. There's the 6888, the 2-tube 6888, the 6LE8, the two-tube 6GY6... now 12-V tubes. Mike Y Dallas, Texas
Well there's an idea, make a BCB tx using 12V space charge tubes
| Top |
35Z5
Post subject: Re: 12AV6-12CS6 Transmitter Posted: Mar Tue 30, 2010 2:10 pm |
| Member |
Hemingray wrote: Well there's an idea, make a BCB tx using 12V space charge tubes
LOL... Done in 24v & 30v versions...
http://www.antiqueradios.com/forums/vie ... p?t=128480
BTW most of the low voltage tubes used in the car radios were not actually space charge types, I believe only the ones used as audio drivers were space charge, other are conventional tubes optimized to operate at low voltages...
Norm's EGM transformer could be used for this low voltage Tx, could even build a "50v" version using the 36v winding for B+...
| Top |
Burnt Fingers
Post subject: Posted: Mar Tue 30, 2010 4:49 pm |
Joined: Oct Sat 20, 2007 3:36 am Posts: 13596 Location: New Hampshire
Sounds like a 3BY6/6BY6 would work also then if using a different filament arrangement.
| Top |
35Z5
Post subject: Posted: Mar Wed 31, 2010 12:58 am |
| Member |
BobWeaver wrote: Tom, How does this transmitter compare to the 6LE8 & 6GY6 transmitters for output power, sound quality etc.? Sound quality is fine, only issue is it's easy to over-modulate with the 12AV6, a audio taper gain control is defiantly recommended... The RF output is approx 65% of the 6GY6, which has the advantage of not over loading the front end of a nearby radio... A 6GY6 version could be built using the CT of the 36v winding to buck the 24v winding, that would require use of a tripler P/S to get the B+ back up to near 150v... Burnt Fingers wrote: Sounds like a 3BY6/6BY6 would work also then if using a different filament arrangement.
Yes the *BY6 works(as does the 5915) but has considerably less Gm on G3, thus requires a higher level of audio input(not necessarily a bad point)...
I'm surprised no ones has commented on the power supply, specifically to the xtal osc...
| Top |
bill hamre
Post subject: Posted: Mar Wed 31, 2010 2:55 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2535 Location: aston, pa, usa
What kinky things have you done to the xtal?
_________________ "All glory is fleeting" - George Patton
KB3QNN 73
| Top |
boxjoint
Post subject: Posted: Apr Thu 01, 2010 3:01 am |
| Member |
Joined: Sep Sun 27, 2009 7:41 pm Posts: 520 Location: Murphy, Texas
Is someone going to be selling all these parts as kits ?
Carlos
| Top |
BobWeaver
Post subject: Posted: Apr Thu 01, 2010 5:21 am |
35Z5 wrote: I'm surprised no ones has commented on the power supply, specifically to the xtal osc...
Hmm, hadn't noticed that. Very clever.
| Top |
35Z5
Post subject: Posted: Apr Tue 13, 2010 2:17 am |
| Member |
Posted updated schematic dated 04-10-10, if you D/L the earlier version(04-01-10), please destroy it...
R7 & R8 have changed value and L3 was added to convert sq wave to a sign, gives improved modulation and a bit more RF output...
Likely this will be the only change ever made to this Tx, I've ran the prototype several hours and am very satisfied with it's performance...
| Top |
boxjoint
Post subject: Posted: Apr Tue 13, 2010 3:10 am |
| Member |
I have already built the pcb section of the circuit with the parts that Bill Hamre sent me. I am looking forward to getting the rest of the parts so I can finish building and try this transmitter.
Can you tell me what type of antenna I should use ?
Carlos
| Top |
Users browsing this forum: gvel and 1 guest |
