| Author |
LawMonkey
Post subject: Repair rigs--what do you guys use? Posted: Apr Thu 01, 2010 8:31 pm |
Joined: Sep Sun 20, 2009 1:09 am Posts: 15 Location: Cincinnati, OH
Not sure if 'rig' is really the right word here. What I'm thinking of is something to hold a chassis at a convenient angle and height for work underneath--something better than my current solution, which is sitting the thing on its side and bending down with a flashlight in my teeth.
I know I've seen some folks post about things here--I remember one that was a free standing contraption suitable for use out on a deck. My work area's got to be a bit more flexible than that--currently it's just a desk that I use for other things, like sitting this laptop on. When I move to NYC in a few months, I doubt things will improve, heh.
Anyway, just curious about how you folks solve this problem. Thanks all!
_________________ Noah
| Top |
nomutantallowed
Post subject: Posted: Apr Thu 01, 2010 8:46 pm |
Joined: Mar Mon 22, 2010 12:51 am Posts: 217 Location: Bloomington,Indiana
I do the same thing as you do.
Maybe I should build a "rig" and put a schematic here?
| Top |
TexMac
Post subject: Posted: Apr Thu 01, 2010 10:32 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2317 Location: Leesburg,TX
Probably 90% of the work I do is on table models or portables. I use a small ramp consisting of a short piece of 1x12 screwed to a section of bevel cut 2x4. I hold the chassis with a pair of 2" C-clamps. Works fine and I can just move the whole contraption off the desk to my workbench if needed. Most of the desk time in the house is just tracing circuits and measuring voltages and values.
_________________ Ron Mc/
| Top |
LawMonkey
Post subject: Posted: Apr Fri 02, 2010 3:37 am |
Simple and smart enough, TexMac. I may see what the guys at the little local lumber yard can do for me along those lines--I don't have woodworking equipment, and they'll build stuff to order. Going to see what they can do about cutting a little pipe box I picked up at the antique mall to use as a case for my nixie clock.
| Top |
TexMac
Post subject: Posted: Apr Fri 02, 2010 7:53 am |
Glad you like it. There have been a couple of similar rigs shown here by others. I have also screwed together a couple of 2x4 pieces flat-to-end that I can place under it to give me a little flexibility in angle of view. Be sure to leave a little overhang on the high side to have room for your clamps.
If doing a console chassis, though, you're going to need something more substantial and probably rotatable. There are several photos of those here as well, but they are overkill for a simple 4 to 6 tube set.
| Top |
Brad B
Post subject: Posted: Apr Fri 02, 2010 1:14 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 894 Location: Columbus, OH USA
This picture is from an old thread here in Hints and Kinks.
On the underside of the holder is a gusset that is glued and screwed in place for strength. The left-to-right board can be longer for stability but takes up more bench space.
| Top |
Stan Saeger
Post subject: Posted: Apr Fri 02, 2010 4:40 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 808 Location: Coopersburg, PA USA
| Top |
hoffies2
Post subject: Posted: Apr Sat 03, 2010 12:47 am |
Joined: Feb Thu 08, 2007 2:32 pm Posts: 7825 Location: USA
I just stand them on edge, power transformer down. Been doing it that way for 50 years.
| Top |
Curt Reed
Post subject: Posted: Apr Sat 03, 2010 12:57 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 34329 Location: Sandpoint, IDAHO 83864
I have no trouble propping up an inverted chassis on cold 807 cans, which are always underfoot.
Curt
_________________ Curt, N7AH
| Top |
Eliot Ness
Post subject: Posted: Apr Sat 03, 2010 1:46 am |
| Member |
Joined: Jan Sun 18, 2009 1:40 am Posts: 2161 Location: Lexington, KY
| Top |
Zenith Guy
Post subject: Posted: Apr Sun 11, 2010 8:25 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1160 Location: Northern Michigan
Well heres mine. I cant take credit for its construction as a metal fab friend of mine built it. It started out over a couple of cold 807s and he put the heavy duty MOJO to it. It locks in any position on 360 degrees.
I have no doubt it would hold the heaviest of chassis. Works great.
Cheers
| Top |
Radiotiques
Post subject: Posted: Sep Thu 30, 2010 8:57 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 761 Location: Wilmington DE USA
I was lucky. I found an original Universal Model A Tel A Turn chassis holder made by Rogers Mfg Co Lindsey OH. It has a built in speaker for testing the output of your equipment, built in socket, and a light. Holds the smallest to largest radio or tv chassis. Has clamps to hold the chassis and a wheel to turn the chassis 360 degress. If anyone wants a picture please send me a PM. The curator at the AWA museum wanted to get it from me but I am holding onto it (at least for now).
| Top |
Don_S
Post subject: Posted: Oct Fri 01, 2010 12:33 am |
Radiotiques wrote: I was lucky. I found an original Universal Model A Tel A Turn chassis holder made by Rogers Mfg Co Lindsey OH. It has a built in speaker for testing the output of your equipment, built in socket, and a light. Holds the smallest to largest radio or tv chassis. Has clamps to hold the chassis and a wheel to turn the chassis 360 degress. If anyone wants a picture please send me a PM. The curator at the AWA museum wanted to get it from me but I am holding onto it (at least for now).
I'd love to see a picture of it and I'm sure a lot of others would too... could you post pictures of it in this thread, please? (the more the merrier!)
| Top |
frankpe
Post subject: Posted: Oct Fri 01, 2010 10:34 pm |
Joined: Feb Tue 02, 2010 3:17 pm Posts: 352 Location: Mississauga (Toronto) Canada
After suffering back pain when working on a chassis on the bench, I put together this jig:
It is super strong mainly because the aluminum frame is made from a old main sail traveller track that I replaced on my sailboat. The red track is a special jig track used in woodworking that accepts 1/4 bolts where the heads slide in a channel. The four fingers can slide up/down, in/out to adjust for chassis size.. The chassis bolts to them via the existing mounts and you can swing it around for the best access. The rest of it was made out of wood/plywood scraps I had lying around.
No more back aches.
_________________ RED - Retired Extremely Dangerous
| Top |
Clutter
Post subject: Re: Repair rigs--what do you guys use? Posted: Nov Tue 15, 2011 10:02 am |
| Member |
Joined: Nov Wed 09, 2011 4:07 am Posts: 171 Location: MD-DC
Here's what I have to do the job. It's a JFD adjustable chassis frame, and it's a real professional piece of gear.  Frame is shown at its max extension of about 24 inches. The rod at the bottom is actually two separate rods that screw together, each about 16in long.  An iron (or steel?) casting (or forging?). The thumbscrew clamps onto the width adjustment rod. The brackets have a pretty wide stance at the base, and are quite stable. It's also easy to clamp it down with bolts or lags and some fender washers, if needed. Painted in the usual black crackle finish typical of the 40's and 50's.  The large disc is firmly clamped between two fender washers by tightening down the thumbscrew. The chassis can be set at any working angle- upright, inverted, or anywhere in between. Nice knurled knobs ~1.5in dia.  The actual clamps are "U" shaped castings. The silver end clamps down on the outside of the chassis. I'm going to use this when I work on my Lysco 600 transmitter. But I would gladly have traded it for 'the Hickok 536 that got away' I think I'm going to be sick over that one. http://antiqueradios.com/forums/viewtopic.php?f=8&t=178688
_________________ Clutter
| Top |
Mrelectronicman
Post subject: Re: Repair rigs--what do you guys use? Posted: Nov Thu 17, 2011 11:22 pm |
| Member |
Joined: Aug Sun 21, 2011 1:07 am Posts: 68 Location: Washington DC
How about this, I saw it in the UK Vintage Radio forum, it's called a Lab Jack
| Attachments: |
_________________ David
| Top |
sofaslug
Post subject: Re: Posted: Nov Sun 27, 2011 7:59 am |
| Moderator |
Joined: Jan Thu 01, 1970 1:00 am Posts: 13320 Location: Berkeley, CA 94709
hoffies2 wrote: I just stand them on edge, power transformer down. Been doing it that way for 50 years.  Pretty much what I do, sometimes with a paperback book as a shim. Bob
| Top |
MAG
Post subject: Re: Repair rigs--what do you guys use? Posted: Nov Sun 27, 2011 8:01 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1740 Location: Lakewood, California
I use Stan Saeger’s stands. Thanks Stan! Small, easy to make, and they don’t take up much storage space between jobs. I built mine from 3/4"” x 2” oak flooring strips left over from a floor repair job. I found the small C-Clamps at Harbor Freight. http://www.saegerradio.com/downloads/Si ... Holder.pdf Most of my work is on car radios and for those I made a chassis block copied from a page in Delco “Testing Tips”. Mine is from a chunk of oak shipping pallet. Lots of other uses besides propping up radio chassis such as a back-up for drilling, gasket punches, beating out a bent panel, etc.
| Attachments: |
_________________ Meade
| Top |
Dennis Wess
Post subject: Re: Repair rigs--what do you guys use? Posted: Nov Mon 28, 2011 1:52 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 3104 Location: Sterling Heights, Michigan 48314, USA
Little one:  Big one:  Made by a gentleman named Steve Strong
_________________ .....Dennis.....
Live Long and Prosper
| Top |
philsoldradios
Post subject: Re: Repair rigs--what do you guys use? Posted: Dec Fri 02, 2011 8:36 am |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 3735 Location: Woodinville, WA USA
I have used stout metal "L" brackets screwed into the chassis mounting holes. You can turn the chassis on any side, or even upside down if it isn't extremely tall. This is an 18-tube Midwest chassis:  Cost: a few bucks. No fancy woodworking required. Screw the brackets onto two boards for "feet," and you can stand up a heavy TV chassis like this Capehart-Farnsworth 661-P:   Regards, Phil Nelson Phil's Old Radios http://antiqueradio.org/index.html
| Top |
Users browsing this forum: No registered users and 0 guests |
