It is currently May Fri 24, 2013 8:06 am
 Post subject: Where is the ad Photos button in the gallery?
PostPosted: Jul Thu 15, 2010 1:17 am
I CANT FIND IT! i GO THE ALBULM BUT I CANT ADD A PIC!!!!!!!! CURT SAVE ME!!!!!!!!!!
As one ages, you find that the cleverness that you posssesed was merely vainty.
PostPosted: Jul Thu 15, 2010 1:23 am
Silent Key
I am like Sgt. Schultz. I know nothing about the photo gallery or how it works.
Curt
Curt, N7AH
PostPosted: Jul Thu 15, 2010 1:32 am
1-You must be "logged in" to the gallery. Logging in to the forums does not mean you are logged in to the gallery.
2-Then you must click on the particular album inside of the gallery that you wish to add a pic.
Only after doing steps 1 and 2 do you reach the starting line for adding pictures.
havven't you ever posted a pic?!!!!
PostPosted: Jul Thu 15, 2010 1:34 am
I have done both of those things. But when you get to the albulm, how do you add your pic!!!!!!!!!!!
PostPosted: Jul Thu 15, 2010 1:48 am
Once you are in a photo album, look for a link labeled "Add Items".
Click that and give it a try.
PostPosted: Jul Thu 15, 2010 1:55 am
Add items isn't there!!!! If it helps, I'm lables as display mode- (screen name)- guest. It's located at the bottom right of the page.
PostPosted: Jul Thu 15, 2010 3:55 am
You're not logged into the Gallery.
A number of people have the same problem as you, and nobody seems to have the answer. It works fine here, except that I can't add photos to a few particular sections.
PostPosted: Jul Thu 15, 2010 1:57 pm
But I pressed the login button on the top of the page and put in my
PostPosted: Jul Fri 16, 2010 2:53 am
When you are properly logged in, the Login will change to Your account, and Logout.
Once Logged in you will indeed see the add items button (text) when you go to the album.
PostPosted: Jul Fri 16, 2010 3:46 am
IT WORKED!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! THANKS RABBIT, GARY
PostPosted: Jul Fri 16, 2010 5:41 am
You are quite welcome :)
If you ned further help, you may PM me.
Gary.
Users browsing this forum: jwburchell and 4 guests
