Page 1 of 1
[ 16 posts ] |
| Author |
solty
Post subject: What the heck is this? Posted: Apr Thu 07, 2011 11:43 pm |
| Member |
Joined: Jan Mon 10, 2011 3:56 am Posts: 80 Location: Dallas, texas
Does anybody know what the heck this is? I found it years ago under a bench when cleaning up at a radio station I worked at. I though it must be some kind of test set...but what?
There are some more pictures in the Temporary gallery.
| Top |
Tony Wells
Post subject: Posted: Apr Thu 07, 2011 11:51 pm |
| Member |
Joined: Oct Sun 18, 2009 5:38 am Posts: 3271 Location: Tyler, Texas 75707-4212
I see a transformer, a variable resistor, and a tungar type rectifier. Must be some power supply of some sort.
_________________ I'm right 97% of the time. Who cares about the other 4%!
| Top |
Alan Douglas
Post subject: Posted: Apr Fri 08, 2011 12:08 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 23530 Location: Pocasset, Cape Cod, MA
| Top |
bruce47
Post subject: Posted: Apr Fri 08, 2011 1:00 am |
Joined: Oct Wed 28, 2009 1:17 pm Posts: 855 Location: Kingston Ontario
Hi
I have one of them bulbs ,so know I what its for.Thank you.
Bruce
| Top |
solty
Post subject: Posted: Apr Fri 08, 2011 5:32 pm |
| Member |
Thanks for the enlightenment. Now I gotta figure out what to do with it. It's too heavy to ship to anybody...cost more than the thing is worth.
| Top |
DHauff
Post subject: Posted: Apr Sun 10, 2011 3:06 pm |
Joined: Nov Mon 23, 2009 6:27 pm Posts: 244 Location: Minneapolis, MN, USA
Plug it in and see what happens!! (just kidding)
| Top |
DavidB_Stein
Post subject: Posted: Apr Sun 10, 2011 6:55 pm |
I have one similar to your, but in place of the resistor, there is a old door spring. I aquired mine about 15 years ago and at that time was told that it was used to provide power to old tube radios, eliminating the need to buy batteries after the county went thru wiring up farms and towns with electrical power. I too have not pluged it in to see how much voltage it will put out. The tube has OS-F marked on it and it has the standard light bulb base. The fuse is stamped 10 Amps.
David S
| Top |
Paul Han
Post subject: Posted: Apr Sun 10, 2011 11:04 pm |
Joined: Apr Fri 23, 2010 4:02 am Posts: 1435 Location: Glastonbury, Ct
I would clean it up and put it on the shelf.
These tungar bulbs have argon in them, right? Do they glow any color when in use?
_________________ As one ages, you find that the cleverness that you posssesed was merely vainty.
| Top |
DavidB_Stein
Post subject: Posted: Apr Sun 10, 2011 11:06 pm |
here are two photos of my battery eliminator.
As you can see in the photo, there are two clips attached to two of the leads. The power cord is the old type two prong plug. The cords are covered in cloth.
David S
| Top |
K7MCG
Post subject: Posted: Apr Mon 11, 2011 12:46 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2038 Location: Seattle WA US
David-
Your "door spring" looks like a piece of a nichrome heating element, being used as a power resistor.
--Chuck
| Top |
solty
Post subject: Posted: Apr Tue 12, 2011 3:24 am |
| Member |
I think I'll have to clean it up and bring it up on a variac and see what happens. I had no idea, but a battery eliminator might be worthwhile to keep around.
Thanks...
| Top |
Chris108
Post subject: Posted: Apr Wed 13, 2011 11:32 pm |
Joined: Jun Fri 19, 2009 6:34 pm Posts: 2676 Location: Long Island
Just be careful. On many old Tungar chargers, the transformer is actually a choke or an autotransformer, and there's no isolation from the AC line.
_________________ "Hell, there are no rules here--we're trying to accomplish something!"
| Top |
solty
Post subject: Posted: Apr Sat 16, 2011 1:06 am |
| Member |
Alan Douglas wins the prize! I'm not sure what the prize is, but he was right. I carefully variac'ed the thing and found that it was indeed a 2 amp battery charger!! The bulb glows pretty brightly at full line voltage and the output, which is line isolated, is about 9 volts at about 2 amps. Good for charging a 6 Volt battery. I should put it in the trunk of my '36 Ford I guess...just in case.
Thanks guys!! Cool stuff.
| Top |
Post subject: Posted: Apr Sat 16, 2011 2:42 am |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 5264 Location: S. Dartmouth MA 02748-1225 USA
Years ago I would find chargers like this lag screwed to the garage wall. Battery cables long enough to reach under the hood of the parked car. The charger was put on on cold nights so the battery would be warm for a fast AM start...
Some of the Tungar chargers were set up with a tapped auto transformer so that a bank of batteries were put in series to be charged. These can deliver some 7 amps at 115 D.C. or so volts so quite a few batteries were on the rack at one time.
_________________ "Don't find fault, find a remedy"
| Top |
MarkPalmer
Post subject: Posted: Apr Sat 16, 2011 6:08 am |
| Member |
Joined: May Mon 18, 2009 5:55 pm Posts: 2025 Location: Erie, PA
Back in those days almost a necessity as car engines were much more of a bear to start than the nice little computerized fuel injected things we have today, and 6 volt electrical systems and starters hardly did the job on a warm morning none the less when it got much below freezing.
-Mark-
_________________ My Current Projects: http://www.facebook.com/#!/pages/Marks- ... 4487855125
| Top |
Buzzsaaw
Post subject: your test rig Posted: Apr Sun 17, 2011 3:15 am |
| Member |
Joined: Apr Sat 02, 2011 3:47 am Posts: 42 Location: NE Montana
Hi guys,
This is simple.. You hook it up to an old AM tower and it removes all traces of pigeon droppings! One puff of smoke and the tower is ready to climb! Those old radio techs really had it swell! No Pita and EPA to worry about. Just get'er-done!
Buzz
| Top |
Page 1 of 1
[ 16 posts ] |
Who is online |
Users browsing this forum: No registered users and 5 guests |
