Joined: Mar Sun 29, 2009 3:34 am Posts: 520 Location: chancellor al.
I have a simple dipole up about 25 ft. with about 75 feet per leg. I plan to use 300 ohm twinlead (hopefully not the Chinese stuff I saw in RS) and conn. a ferrite loopstick across the twinlead inside shop. I think a secondary (may have one already) of lower imped. would be ok to conn to radios on bench.
I would welcome any comments pro or con on this project.
I do plan to have a lightning arrestor of some type on lead in.
Joined: Aug Sat 29, 2009 12:06 pm Posts: 294 Location: Milford, CT
If this is for the AM band then don't even bother with the dipole. At 150 feet it's no where reasonant for the AM band. It will work but why go through al the trouble? If you are using it to test radios, any lenght of wire strung outdoors is fine.
Use the loopstick. It will increase signal strength especially on low power stations but the main advantage is it will reduce interference from shop tools, chargers, and lighting.
Joined: May Tue 30, 2006 4:46 pm Posts: 4792 Location: Santa Rosa, CA
Sorry, I am mystified.
Reducing interference would require reducing signal strength, unless you have found a way to tune the loopstick to the offending interference.
The loopstick Q drops off dramatically above and below the band it is designed for. It will not reduce actual BCB noise but will reduce everything else. They are especially good in reducing fluorescent interference.
