Page 1 of 1
[ 16 posts ] |
| Author |
HuggyBear
Post subject: I need to see if this will work... Posted: Sep Thu 27, 2007 2:28 am |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 6804 Location: Warren, MI, USA 48093-6744 N42.50973 W83.02633
Many people have told me this will never work...but I need to see for myself.
If it DOES work, I will build it nicer...but this should show once and for all if it will work.
Yes, that's a 6BK4 and a 6SN7...
_________________ The mind is like a parachute - just because you lost yours doesn't mean you can borrow mine.
| Top |
Norm Leal
Post subject: Posted: Sep Thu 27, 2007 3:16 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 29157 Location: Livermore, CA
Bill
It will work if you use the 6BK4 as a detector and 6SN7 as audio amplifier.
6BK4 was made for high voltage but it's a triode. Transconductance is only 200 with plate current less than 1 ma. The 6BK4 in your photo had a lot of use..
_________________ Norm
| Top |
Peter Bertini
Post subject: Posted: Sep Thu 27, 2007 3:24 am |
| Moderator |
Joined: Jan Thu 01, 1970 1:00 am Posts: 12453 Location: Somers, CT
Norm Leal wrote: Bill
I 6BK4 was made for high voltage but it's a triode. Transconductance is only 200 with plate current less than 1 ma. The 6BK4 in your photo had a lot of use..
Bet you could do xrays with that tube
| Top |
Norm Leal
Post subject: Posted: Sep Thu 27, 2007 3:48 am |
Right but think you would need 30KV?
| Top |
HuggyBear
Post subject: Posted: Sep Thu 27, 2007 4:01 am |
| Member |
That is exactly what I intend to do with it Quote: 6BK4 was made for high voltage but it's a triode. Transconductance is only 200 with plate current less than 1 ma. The 6BK4 in your photo had a lot of use..
True, and it's a 6BK4C / 6EL4A. I can't find it right at the moment but I have a NOS 6BK4A. Not an ideal tube for TV use, but I bet it would do as a detector.
More than a few people have told me it won't conduct with less than 20,000 volts on it - I say if the Audion worked, this should work too. I plan on running about 150 volts on the plate.
| Top |
HuggyBear
Post subject: Posted: Sep Thu 27, 2007 4:24 am |
| Member |
Peter Bertini wrote: Norm Leal wrote: Bill
I 6BK4 was made for high voltage but it's a triode. Transconductance is only 200 with plate current less than 1 ma. The 6BK4 in your photo had a lot of use.. Bet you could do xrays with that tube
At 150v on the plate, it won't put out any more X-rays than a 5Y3...
| Top |
Toad
Post subject: Posted: Sep Thu 27, 2007 4:33 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1078 Location: Zip : 80751
Let me know if it works. I have a used one, and a new one to try if it works. Got to find em of course, there buried somwhere.......
I think it will work
Jeremy
| Top |
35Z5
Post subject: Posted: Sep Thu 27, 2007 5:46 am |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 8701 Location: Chesapeake VA
Been thinking I'd try one at about 1200v on the plate to see if it will actually amplify... I have a old scope transformer that used a 1V2 rect into a couple .2 caps... Just tried it and it's good, so one of these days I'll give it a shot...
If that doesn't do it, I have a bug zapper xfomer and some HV triplers for TVs...
| Top |
HuggyBear
Post subject: Posted: Sep Thu 27, 2007 11:55 am |
| Member |
35Z5 wrote: Been thinking I'd try one at about 1200v on the plate to see if it will actually amplify... I have a old scope transformer that used a 1V2 rect into a couple .2 caps... Just tried it and it's good, so one of these days I'll give it a shot... If that doesn't do it, I have a bug zapper xfomer and some HV triplers for TVs... Tom
There are far better tubes to use for this, I know that. The 6BK4 oly has a mu of about 2. The mission here is NOT to create the best 2-tube regen ever, it is to see if the 6BK4 will work at <200 volts on its plate. Some say it will not, I say it will.
Your scope power transformer...I think that will work, probably not a lot of tubes that can tolerate 1200v on the plate.
But - what would you do with it? Signal in shouldn't be a problem, but the rather high output voltage...you'd need a special cap just for coupling (the standard 630v cap wouldn't be adequate). An interstage transformer would have to have a very high impedance - here's an idea - perhaps using a flyback as an interstage transformer. Now that would get noticed!
My first regen radio I built when I was about 10 years old used an 01A. That worked well, despite the fact that I had no idea what I was doing.
| Top |
35Z5
Post subject: Posted: Sep Thu 27, 2007 1:32 pm |
| Member |
HuggyBear wrote: But - what would you do with it? Signal in shouldn't be a problem, but the rather high output voltage...you'd need a special cap just for coupling (the standard 630v cap wouldn't be adequate). An interstage transformer would have to have a very high impedance - here's an idea - perhaps using a flyback as an interstage transformer. Now that would get noticed!
No prob, I have some 1600/2000v caps for TVs and a few 1600v buffer caps for car radios... Values may be a bit small, but I should be able to test operation...
BTW, I'm not beyond sticking caps in series to increase voltage ratings...
| Top |
Norm Leal
Post subject: Posted: Sep Thu 27, 2007 2:20 pm |
6BK4 will conduct at lower voltage. Think of it this way, a lot of tube testers only use a couple hundred volts, some much less. You can test 6BK4's on tube testers.
| Top |
35Z5
Post subject: Posted: Sep Thu 27, 2007 2:38 pm |
| Member |
Norm Leal wrote: 6BK4 will conduct at lower voltage. Think of it this way, a lot of tube testers only use a couple hundred volts, some much less. You can test 6BK4's on tube testers.
Yes I confirmed that last night on a Precision 912 before I jumped into this post... Grid voltage set to max and load at minimum, nets approx 25% deflection on the meter, which is indicative of a good tube... Reducing grid signal lowers the reading, so it is apparently amplifying(if only a little)...
Since the tester uses 300v plate supply, I'm guessing it will take somewhat more voltage to achieve any real amplification...
| Top |
Norm Leal
Post subject: Posted: Sep Thu 27, 2007 2:49 pm |
Nice thing about a regen, it doesn't need a tube with high gain. As long as gain is over 1 feedback from tickler coil increases the signal.
| Top |
Peter Bertini
Post subject: Posted: Sep Fri 28, 2007 2:44 am |
| Moderator |
Norm Leal wrote: Right but think you would need 30KV?
Sure it would, but just kidding
| Top |
Paul Han
Post subject: Posted: Apr Thu 28, 2011 3:00 am |
Joined: Apr Fri 23, 2010 4:02 am Posts: 1435 Location: Glastonbury, Ct
Hey!
What happened to this?
_________________ As one ages, you find that the cleverness that you posssesed was merely vainty.
| Top |
KeeperOfTheGood
Post subject: Posted: Apr Thu 28, 2011 5:35 am |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1935 Location: Burlington, Ontario, Canada
 here here what was the verdict how far were the ideas/trials taken?
_________________ // scriptio in pace
// pax lineamenti
| Top |
Page 1 of 1
[ 16 posts ] |
Who is online |
Users browsing this forum: No registered users and 3 guests |
