It is currently Jun Wed 19, 2013 1:47 am
 Post subject: Antenna For Shop
PostPosted: Apr Wed 27, 2011 1:13 am
I have a simple dipole up about 25 ft. with about 75 feet per leg. I plan to use 300 ohm twinlead (hopefully not the Chinese stuff I saw in RS) and conn. a ferrite loopstick across the twinlead inside shop. I think a secondary (may have one already) of lower imped. would be ok to conn to radios on bench.
I would welcome any comments pro or con on this project.
I do plan to have a lightning arrestor of some type on lead in.
Harold
PostPosted: Apr Wed 27, 2011 6:10 pm
I don't think you really need a loopstick antenna on the feed wire.
I use a 75' antenna ( in an "V" shape to make it an omnidirectional) and earth ground to a patch panel in my shop.
I can then come off the binding posts for the connections to the radio.
For radios with a loop on the back I found hooking a coil of wire to make an inductive coupling works just great.
FrankB
WB7ELC
Member: TCA
"I know that all that is wrong with it is one little part".
PostPosted: Apr Thu 28, 2011 2:10 pm
Agree. Just use the antenna lead in and ground for your connections. Loopstick not needed.
Chuck
Chuck Schwark,
The Philco Repair Bench
Schematic Photocopy Service
www.philcorepairbench.com
PostPosted: May Sat 28, 2011 1:00 am
Location: Harviell MO USA 63945 (12 miles S of Poplar Bluff)
Of course that "V" must be in the horizontal plane to make it more omnidirectional. A "V" in the vertical plane does nothing for that.
Dean, Electronics Curmudgeon
Contributing editor emeritus in Poptronics magazine, R.I.P.
 Post subject: Re: Antenna For Shop
PostPosted: Aug Sun 07, 2011 12:43 pm
If this is for the AM band then don't even bother with the dipole. At 150 feet it's no where reasonant for the AM band. It will work but why go through al the trouble? If you are using it to test radios, any lenght of wire strung outdoors is fine.
PostPosted: Aug Wed 10, 2011 3:12 pm
Use the loopstick. It will increase signal strength especially on low power stations but the main advantage is it will reduce interference from shop tools, chargers, and lighting.
PostPosted: Aug Wed 10, 2011 7:26 pm
Sorry, I am mystified.
Reducing interference would require reducing signal strength, unless you have found a way to tune the loopstick to the offending interference.
In my opinion, the loopstick is not needed.
PostPosted: Aug Wed 10, 2011 7:44 pm
The loopstick Q drops off dramatically above and below the band it is designed for.
It will not reduce actual BCB noise but will reduce everything else. They are especially good in reducing fluorescent interference.
Post New Topic Post Reply  [ 8 posts ]  Moderator: Chuck Schwark
