Page 1 of 1
[ 20 posts ] |
| Author |
nostalgiafever
Post subject: H/K unknown Am/FM Stereo receiver Posted: Aug Fri 26, 2011 7:11 am |
Hi: I am repairing a Harman Kardon Tube Amplifier that need to know model to get schematics. It uses 4 7408 tubes and 3 12AX7 for the preamp/amp stage. Anybody there knows this model? Any help will be greatly appreciated. Thanks
Last edited by nostalgiafever on Aug Sun 28, 2011 3:32 am, edited 1 time in total.
| Top |
Johnnysan
Post subject: Re: H/K unknown Am/FM Stereo receiver Posted: Aug Fri 26, 2011 10:09 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 11441 Location: Albuquerque, NM 87123
| Top |
ke4mcl
Post subject: Re: H/K unknown Am/FM Stereo receiver Posted: Aug Fri 26, 2011 4:21 pm |
Joined: Jan Mon 12, 2009 7:38 am Posts: 872 Location: miami fl
| Top |
nostalgiafever
Post subject: Re: H/K unknown Am/FM Stereo receiver Posted: Aug Fri 26, 2011 7:52 pm |
Understand A300 and A500 are just Amplifiers. Mine is Am/FM receiver/amplifier. Thanks for your help. Will try to post pics. (Don't know how to)
| Top |
Brian McAllister
Post subject: Re: H/K unknown Am/FM Stereo receiver Posted: Aug Fri 26, 2011 10:28 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2555 Location: Sarasota FL USA
| Top |
nostalgiafever
Post subject: Re: H/K unknown Am/FM Stereo receiver Posted: Aug Sun 28, 2011 3:30 am |
Here is one picture of the mystery HK am/fm amplifier into a churchill sr1000 console..Who knows chassis number or amplifier number!!!
| Attachments: |
![IMG_0257[1].jpg](./download/file.php?id=4162&sid=71875117690a47815b632813783db0a4)
| Top |
nostalgiafever
Post subject: Re: H/K unknown Am/FM Stereo receiver Posted: Aug Sun 28, 2011 3:46 am |
More pictures: top view, rear view H/k into Churchill sr1000 console:
| Attachments: |
![IMG_0256[1].jpg](./download/file.php?id=4165&sid=71875117690a47815b632813783db0a4)
![IMG_0255[1].jpg](./download/file.php?id=4164&sid=71875117690a47815b632813783db0a4)
| Top |
nostalgiafever
Post subject: Re: H/K unknown Am/FM Stereo receiver Posted: Aug Sun 28, 2011 10:10 pm |
Who knows model number??? Where to get copy of schematics. Prefer original Sam's Photofact!!!
| Top |
Tom Bavis
Post subject: Re: H/K unknown Am/FM Stereo receiver Posted: Aug Tue 30, 2011 12:43 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 3852 Location: Rochester NY USA
I've seen a similar one, maybe the same, labeled "E J Korvette" (NY/NJ department store in the '60s). Neither brand is listed in Sams index at all, and the only "SR-1000" listed is Marantz, no relation to this one. So maybe your best be is to use a similar model like the TA-230 or TA-224 - I have the schematic for the 230 - email tbavis(at)rochester(dot)rr(dot)com
| Top |
nostalgiafever
Post subject: Re: H/K unknown Am/FM Stereo receiver Posted: Sep Thu 01, 2011 7:50 pm |
Hi: thanks for the info. TA-230 uses 6bq5 as amplifier tubes. Mine uses 3 12AX7 for preamp. and four (4) 7408 (6V6) for amp. I understand circuits are quite different. Thanks anyway for your help (I also have 230's schem.)
| Top |
Tom Bavis
Post subject: Re: H/K unknown Am/FM Stereo receiver Posted: Sep Fri 02, 2011 1:22 am |
The A-230 amplifier uses 6BQ5, but the TA-230 receiver schematic I have uses 7408s.
| Top |
nostalgiafever
Post subject: Re: H/K unknown Am/FM Stereo receiver Posted: Sep Sat 03, 2011 2:36 am |
Thanks to all that tried to help. Amplifier already working (no model nor schematic found...just testing parts solved the problem).
| Top |
Keith
Post subject: Re: H/K unknown Am/FM Stereo receiver Posted: Oct Mon 03, 2011 10:57 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 416 Location: Antioch, Illinois Near the Cheddar Curtain Go White Sox!
A past eBay sale said that the SR1000 may also be known as the Harman Kardon PLR-3, but I find no info on that either.
| Top |
Tube Radio
Post subject: Re: H/K unknown Am/FM Stereo receiver Posted: Oct Tue 04, 2011 12:18 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 7879 Location: Warner Robins, GA
Ensure all electrolytic capacitors have been replaced along with all paper capacitors then check for and replace all out of tolerance resistors. I see yours has an external MPX decoder attached.
| Top |
codefox
Post subject: Re: H/K unknown Am/FM Stereo receiver Posted: Oct Tue 04, 2011 5:29 pm |
The output tubes (7408) is equivalent to 6V6, which is much easier to find should you need replacements.
| Top |
8417
Post subject: Re: H/K unknown Am/FM Stereo receiver Posted: Oct Wed 05, 2011 3:19 am |
Joined: Mar Wed 16, 2011 4:17 pm Posts: 47 Location: NYC
| Top |
8417
Post subject: Re: H/K unknown Am/FM Stereo receiver Posted: Oct Wed 05, 2011 3:37 am |
Churchill was a console manufacturer, and utilized Harman Kardon in the early 60's as a supplier.
In addition to your unit- there are also Churchill versions of the A300 and the A500. The receiver appears to be the only Churchill unit, that was not an off the shelf item from Harman Kardon.
All of the Harman Kardon 7408 units are almost virtually identical circuit wise, so you can use one of those schematics until the one day an original Churchill manual appears.
| Top |
vintagevermont
Post subject: Re: H/K unknown Am/FM Stereo receiver Posted: May Thu 03, 2012 7:51 pm |
I am new to this forum, but I recognized the Churchill amp IMMEDIATELY from the pictures. My parents bought a big walnut console with this exact receiver. Churchill had a store on Route 110 in Suffolk County, just off Northern State Parkway (on the way to what would be Walt Whitman Mall). I remember my parents shopping for this unit; I would guess about 1962 or so. I have the exact amp (working) with a slightly different faceplate and YES, I do have SCHEMATICS. I'll scan them in later if you like. I also don't know what the model is, but the back says"PLR-3", as in your photo. I am just starting to think about a rebuild.
| Top |
swanson
Post subject: Re: H/K unknown Am/FM Stereo receiver Posted: May Thu 03, 2012 8:17 pm |
That makes sense because Harman Kardon was in Westbury back then. Regards, Swanson
| Top |
BigBandsMan
Post subject: Re: H/K unknown Am/FM Stereo receiver Posted: May Thu 03, 2012 8:18 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 6032 Location: Raleigh NC USA
Welcome aboard, VV, and looking forward to hearing about your rebuild.  Larry
_________________ It don't make a go if it ain't got that GLOW!
| Top |
Page 1 of 1
[ 20 posts ] |
Users browsing this forum: No registered users and 0 guests |
