Page 1 of 1
[ 15 posts ] |
| Author |
Copiertech
Post subject: General Philosophy on Realignment Posted: Nov Sat 19, 2011 5:10 pm |
Joined: Nov Sun 08, 2009 9:48 pm Posts: 301 Location: Fredericton, Canada
Generally , I don't realign sets that seem to be "OK" but lately I have discovered that a partial alignment can do wonders for a set that has had a complete re-capping. I have gone back to a couple of AM-FM- shortwave sets that I recapped 3 years ago but was reluctant to do any alignment because the service data was in German and Dutch. I know more about these sets now and, working backwards from the last IF, adjusted just the If transformers to get the best sound for the AM and FM bands. It improved the sensitivity remarkably. They didn't need much turning but the result was very pleasing. For FM I did not touch the secondary coil for the ratio discriminator, just the primary. I did not adjust any of the other trimmers or padders. In addition, I did not need to use my signal generator. I just tuned to a weak station on each band and did the adjusments. A couple of the iron cores were frozen, so I needed to unfreeze them. I used a hair dryer to warm them up and this loosened them up nicely and they stayed loose even after cooling off. I hope this helps anyone who feels intimidated by a radio they don't know much about.
_________________ Worry is like a rocking chair. It keeps you busy but doesn't get you anywhere.
| Top |
Johnnysan
Post subject: Re: General Philosophy on Realignment Posted: Nov Mon 21, 2011 6:50 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 11441 Location: Albuquerque, NM 87123
That is pretty much the procedure I use. If a radio is un-molested the alignment is A) probably not 100%, and B) not off by much.
A little tweaking does wonders sometimes.
| Top |
Brian McAllister
Post subject: Re: General Philosophy on Realignment Posted: Nov Mon 21, 2011 12:06 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2554 Location: Sarasota FL USA
In the late '50s and early '60s, when I worked for a shop that serviced many German AM-FM radios, we used a similar procedure, with the following differences:
The FM was tuned to an empty spot near the high end of the dial. the volume was raised to where you could hear the inter-station hiss. The secondary of the detector transformer was de-tuned slightly, to increase the hiss. Working backwards through the IFs, tune for maximum hiss. Re-tune the secondary of the detector for minimum hiss and you are finished.
_________________ Brian McAllister Sarasota FL http://oldtech.net
| Top |
Copiertech
Post subject: Re: General Philosophy on Realignment Posted: Nov Mon 21, 2011 1:17 pm |
Thats a good tip Brian. I'll try that next time.
| Top |
gearhead222
Post subject: Re: General Philosophy on Realignment Posted: Nov Sun 27, 2011 7:33 am |
Joined: Dec Sat 22, 2007 7:12 am Posts: 1951 Location: Great State of Texas!
Good subject! That being said, it is VERY easy to break composite Ferrite adjustable cores in IF cans! (don't ask me how I know). If either one breaks, resonance will stop:( Better to try to loosen them up as suggested and try turning with a plastic tweaker. If that doesn't work, then leave them alone-sometimes the mark of a competent technician is knowing when to stop. My .02:)-Gearhead.
| Top |
mescalero
Post subject: Re: General Philosophy on Realignment Posted: Nov Mon 28, 2011 7:20 pm |
Joined: Feb Thu 24, 2011 1:29 am Posts: 2800 Location: Dallas, TX - in the city but with bobcats and coyotes
gearhead222 wrote: ..-sometimes the mark of a competent technician is knowing when to stop. My .02:)-Gearhead. Amen to that! Sometimes the most valuable lessons are the hardest-earned.
_________________ In a triode, no one can hear you screen.
| Top |
gadget73
Post subject: Re: General Philosophy on Realignment Posted: Nov Mon 28, 2011 8:38 pm |
Joined: Mar Tue 04, 2008 8:28 pm Posts: 3416 Location: New Jersey
I was once told that experience is what you get the moment after you needed it. I've broken too many of those IF slugs to be interested in forcing them anymore. If they don't move easily with the plastic tool, they stay put. I've got an old Japanese-built tube CB that has most of the ferrite slugs cracked. Not all of them were me, but at least one is. Thats going to be a real treat. Once I get them out, then I have to figure out replacements.
_________________ Saving vintage electronics, one dumpster at a time.
| Top |
wazz
Post subject: Re: General Philosophy on Realignment Posted: Dec Tue 06, 2011 7:10 am |
| Member |
Joined: Jun Wed 08, 2011 2:33 am Posts: 2047 Location: Ohio
THose German radios-when I look at the schematics, I get dizzy. Have not tried alignment on one yet, due to insufficient data on what is where and how, etc.
| Top |
codefox
Post subject: Re: General Philosophy on Realignment Posted: Dec Wed 07, 2011 5:06 pm |
If and when I get a radio going, I perform an exploratory inspection to see if an alignment can reasonably be attempted toward a betterment in reception. I'll leave the compicated European sets to my betters.
| Top |
Dennis Daly
Post subject: Re: General Philosophy on Realignment Posted: Dec Mon 19, 2011 4:16 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 3790 Location: Malone, New York USA
I've never met a post-war German radio that hasn't benefited from a proper instrument alignment.
It's part of the learning curve. Some promote it, some rationalize against it, some won't admit it.. I personally consider it part of the fun and satisfaction to make the radio perform its best.
| Top |
Tubenut
Post subject: Re: General Philosophy on Realignment Posted: Dec Tue 27, 2011 1:05 am |
Joined: Oct Sun 11, 2009 10:06 am Posts: 1441 Location: British Columbia
I think one has to realize that these radios are 40+ years old, and at least one tech that had "no idea" has probabily had his or her hands in it at one time or other. An alignment is always necessary, even if just to make sure its running at it's best. Unless you re-tune the IF and RF slugs or caps, how do you know if its running properly? Now here is where a scope or spectrum analyzer is involved. Some say "They are not needed." To do an "above average" alignment, "yes they are." When the IF is tuned properly, this is what it will look like on a spectrum analyzer. The "IF" is 462.500kHz
| Top |
Alan Douglas
Post subject: Re: General Philosophy on Realignment Posted: Dec Wed 28, 2011 12:52 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 23507 Location: Pocasset, Cape Cod, MA
Can you use a "diddle stick" (ferrite on one end, brass on the other) to check IF transformers?
| Top |
Tubenut
Post subject: Re: General Philosophy on Realignment Posted: Dec Wed 28, 2011 1:41 am |
Alan Douglas wrote: Can you use a "diddle stick" (ferrite on one end, brass on the other) to check IF transformers? I find a sharpened candy cane works much better around Christmas time.
| Top |
fifties
Post subject: Re: General Philosophy on Realignment Posted: Dec Wed 28, 2011 2:31 am |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 8695 Location: SoCal, 91387
Tubenut wrote: Unless you re-tune the IF and RF slugs or caps, how do you know if its running properly? Now here is where a scope or spectrum analyzer is involved. Some say "They are not needed." To do an "above average" alignment, "yes they are." When the IF is tuned properly, this is what it will look like on a spectrum analyzer. The "IF" is 462.500kHz
Agreed that almost every old receiver could benefit from an RF/IF alignment, and actually even if never recapped, simply because the majority of components have proven themselves to drift in their values over the decades. That said, it would have to be understood that most hobbyists don't own a sweep-marker spectrum analyzer, and although using such an instrument could very likely achieve the pinnacle of perfection, that peak would be relevant in only a small percentage of listening exploits for most AM radio users, generally involving DXing very weak signals. I think for the majority who restore old sets just for themselves, peaking by ear using either a weak AM station or a signal generator tone, provides a sufficiently acceptable alignment process.
_________________ *******\\\\\\\\\******He Who Dies With The Most Radios Wins******/////////*******
| Top |
tubeAMP
Post subject: Re: General Philosophy on Realignment Posted: Jan Mon 23, 2012 1:34 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2753 Location: Gainesville, Florida
I saved that FM alignment. thanks to Brian
_________________ CAUTION: Im no expert
| Top |
Who is online |
Users browsing this forum: No registered users and 0 guests |
